what is my 1/4 time
Old Feb 19, 2008 | 12:05 PM
KillaItalian904's Avatar
I have seen evo drivers hit 12 flat with air filter, exhaust, boost controller, and tune. Really good drivers though
Old Feb 19, 2008 | 12:37 PM
philevo's Avatar
12.6-12.8@105-106
Old Feb 19, 2008 | 12:45 PM
AlwaysinBoost's Avatar
high 12s
Old Feb 19, 2008 | 12:47 PM
Turbolover's Avatar
13flat
Old Feb 19, 2008 | 01:13 PM
lemmonhead's Avatar
come on you think i would only get 1/10-2/10 of a second from a stock evo?
I got a full 3" turbo Back exhuast (tanabe blue G) with 24psi peak with 20 psi to redline. no way will i be in the 13's with that. so 12.2 with 100oct timing w/26psi.
so my 12.5 seems feasible.
Originally Posted by Boost3dxEvO
Here is a comparison for you.... I have 2 friends that drive IX's .. One has Stage 1 Buschur (tbe, drop in filter, mbc, and flash) with 110 octane and 26psi he ran 12.2.. I have another friend with a stock 9 that ran 13.2.. so for you I would say high 12's .. maybe 13.0-13.1 . just depends on how good of a driver you are.
Old Feb 19, 2008 | 01:26 PM
Charlie_B's Avatar
You have to consider that with your 1st time out on the track, you will probably not see 1.7 60's. More like 1.9-2.1. There's .2-.3 seconds. And thats not considering how well you shift from 2-3 and 3-4.
First off, dont go to track with high expectations. You will be dissappointed. Set your goal to be in the 12s, and go from there. But dont be dissappointed if you can only turn a 13.0. The car is only part of the equation...
Old Feb 19, 2008 | 01:32 PM
psphinx81's Avatar
15.573
Old Feb 19, 2008 | 01:35 PM
boostedwrx's Avatar
13's unless you can get a good launch and 1-2 shift.
Old Feb 19, 2008 | 01:39 PM
bigric09's Avatar
i really hope you reply back with what you ran.... if you run anything faster than a 12.5 or so.... ill be amazed.
Old Feb 19, 2008 | 01:44 PM
MillDogg13's Avatar
It all depends on how well you drive, but with the mods mentioned i would say 12.7 is possible.
Old Feb 19, 2008 | 02:06 PM
lemmonhead's Avatar
i will post up my time when i do it. even if its a 13.8 evo X time, hahahha
thanks for the replys guys.
Old Feb 19, 2008 | 02:23 PM
EvoBroMA's Avatar
i ran high 13s to 14.0 my first time at the track. granted it was 90* out, and my car was full of crap.
Old Feb 19, 2008 | 02:28 PM
deanner's Avatar
It should run 12.6-12.8@105-106 with a desent 60ft 1.7 will do!
Old Feb 19, 2008 | 02:50 PM
evo8426's Avatar
i dont think that just an exhaust will give him that time
Old Feb 19, 2008 | 04:09 PM
Evoluvin's Avatar
it all depends on how good of a driver you are.... go to the track!
