The "Official" Evo Modding for Dummies
Old Sep 4, 2010 | 01:45 PM
  #466
MRmike's Avatar
Originally Posted by Sacevo9mr
hey have 06 Evo 9 Mr, looking to get some extended lug nuts, does anybody know the lug size? i just got the car yesterday
I believe Touge Factory could hook you up with extended lugs and spacers if you need em. Thats where I got mine from.
Old Sep 4, 2010 | 01:53 PM
  #467
chaotichoax's Avatar
glad to see this thread is still helping people
makes it worthwhile for me
Old Sep 4, 2010 | 02:38 PM
  #468
MRmike's Avatar
i'm looking into fabbing my own intake pipe, but have been debating on which size to go with. Would 4" pipe be overkill on how much a BBK full can actually intake or should I stick with the norm 3"?
Old Sep 6, 2010 | 05:14 PM
  #469
JACOB3RD's Avatar
This thread is great,but i need help what mods could i run safely without needing a tune?
Old Sep 6, 2010 | 05:17 PM
  #470
evoboi005's Avatar
none ? maybe cat back exhaust ?
Old Sep 7, 2010 | 09:33 AM
  #471
EGbeater's Avatar
My Evo makes well over 400 wtq/whp (uncorrected figures) on a CBRD BBK full with a very simple/relatively inexpensive intake system:
$39 MAP cone filter/MAF adapter plate: http://www.maperformance.com/vibrant...apter-evo.html
$130 Samco silicone intake pipe: http://www.lancershop.com/customer/p...?productid=877
However, FP claims you'll get less surge/part-throttle bucking and a little more power with this 84mm (3.3") inlet surge cover from FP for the BBK ($200), which requires their matching inlet pipe ($110) or that you fab something up yourself that matches it:
http://store.forcedperformance.net/m...Lancer-TurboHW
http://store.forcedperformance.net/m...=Lancer-Intake
Old Sep 9, 2010 | 12:05 PM
  #472
dmitirygolos's Avatar
how often would u need to change ur filter?
Old Sep 11, 2010 | 09:04 PM
  #473
vuqdao's Avatar
GREAT INFO! Thanks!
Old Sep 15, 2010 | 06:54 PM
  #474
WhItEVIII's Avatar
Awesome thread haven't read it all but I will eventually. This is the type of thread that even if you've never work on a car before you'd be able to no problem, very easy to understand.
Old Oct 4, 2010 | 01:37 PM
  #475
dolson222's Avatar
EBC options
This may be the wrong thread for this but I would like to learn about EBCs in a possibly less hostile environment. I had juust found agreat deal on here for a blitz id3 but I was wondering how that system would differ from say one of the 3 port solenoid ebcs. It seems that the 3ports that I had seen being voted on in another forum use the stock ecu connection and I guess the tune would iron the rest of the boost control out. what would be the advantage to the id3 other than a fancy boost display. (I assume the tuning of a 3 port solenoid would simulate the prgressive controller in the id3) Will the id3 give an option to run at a lower boost rate with the touch of a button. (or is that a more practical/typical adjustment for a stand alone ECU) I say the Blitz id-3 but there seem to be a few other similar options (Greddy, ect) (just to not show any or bias) I just want to undeerstand the differences in functionality.
Old Oct 4, 2010 | 02:19 PM
  #476
GG06MR's Avatar
I can't really tell you anything about the Blitz id-3, but you can adjust boost easily with the EBCS by simply setting up map switching. Seems like most people do it to have a 93 octane map and an E-85 map, but you could, for example, easily have a high and a low boost map for 93 octane. Not necessarily settable on the fly, but still adjustable if you feel the need to reduce boost levels quickly.
Old Oct 5, 2010 | 09:01 AM
  #477
dolson222's Avatar
Thats awesome info. Thanks gg06. I am leaning toward that option more and more. Its only like 100$ for the three port solenoids unlike the others but im still curious. Anyone know anything about the functionality of the other style?
Old Oct 5, 2010 | 09:17 AM
  #478
GG06MR's Avatar
Here's a few links that I recommend you review about ECU controlled boost......
https://www.evolutionm.net/forums/ec...t-control.html
https://www.evolutionm.net/forums/ec...hramod-v7.html
Old Oct 19, 2010 | 06:37 PM
  #479
seanr8368's Avatar
Thanks but....
Just got 2010 evo Se and read newbie stuff, problem is i dont know **** about cars, my last and still have is a lifted jeep so all i know is suspension and gears, i just want to do some simple mods without guages and psi numbers and fuel ratios, that i dont understand. So im thinking intercooling pipes u mentioned , maybe cold air intake anything else u suggest, and where do i get this stuff is one site better then another? Thanks for the help
Old Oct 22, 2010 | 02:15 PM
  #480
vito's Avatar
Thanks!!
