Stock Turbo Unite!
Old Mar 9, 2008 | 09:00 AM
SpeedJunkyz's Avatar
Stock Turbo Unite!
I wanted to start my own stock turbo thread on here to see where people are at and what they plan on doing.
If you have a stock turbo please post your supporting mods and your HP to the wheels. I want to see what people are getting out of their stocker turbo. I plan on upgrading mine sometime in the future, but lets see how long it will hold up.
Please post the mods that actually support Power/torque. All the other add ons are not required(i.e. gauges, strut bars, harnesses, etc, etc.) since they really don't play a part in power build.
I have not dynoed mine yet, but Im sure its NOT over 300. I dont have very many mods.
Mine are as followed:
Walbro fuel pump
Injen Upper/lower IC pipe/ Intake
Custom TBE/ Turbo XS Cat back
Jester Tuned/ laptop hook up and WOT runs(Whatever he did lol Ill trust him)
Soon to come:
280/280 cams
Injen IC Core
NX intercooler sprayer
more to come, im still planning
im sure this type of thread has already been started, but i wanted to start one for my reference.
SJ
Old Mar 9, 2008 | 09:09 AM
ohEVO18's Avatar
im liking the idea behind your thread.
I dont have many mods, but I am planning on sticking with the stock turbo for a goo while as I DD my car, and dont want to run into reliability issues.
I have not run on the dyno yet, but plan to soon.
Mods are as follows:
full 3" turbo xs TBE
K&N drop-in
Buschur MBC
installing an ETS LICP this week
I also have a stock manifold I am going to be sending off to get ported, but am waiting to get a 10.5 hotside and an o2 housing. After that, I am looking at an ETS intercooler and UICP and MAF intake, cams, pump and injectors.
i obviously am not over 300 wheel, but hope to be soon
Old Mar 9, 2008 | 10:16 AM
igo4bmx's Avatar
stock turbo should be clarified for 10.5 hotside turbos
Old Mar 9, 2008 | 10:21 AM
SixOneNine's Avatar
My stocker put down 307whp at 25 psi (100 oct) and 290whp at 22 psi (91 oct) on a Dyno Dynamics. This was on a slipping clutch so it could have made more. This dyno reads 15-18% lower than a Dynojet. So about 350ish on a Dynojet on my race gas map?
Supporting mods:
- HKS Hi-Power catback
- Skunk2 test pipe
- Tanabe down pipe
- Megan 02 housing
- Ported 9.8 hot side (basically a 10.5?)
- Ported exhaust manifold
- Greddy Vspec FMIC
- Dejon Tool MBC
- MR metal bov
- K&N drop in air filter
- Walbro fuel pump
- ARP head studs
- HKS 264/264 cams
Plan on getting a new clutch first. Then Green, 720cc, licp, and retune w/ 2 maps by summer or fall.
Old Mar 9, 2008 | 10:29 AM
TURBevO8's Avatar
DC Sports heatwrapped downpipe/testpipe
HKS 30th Anniversary cat back exhaust
HKS 272 intake and exhaust camshafts
APS blow off valve
APS cold air intake
APS intercooler sprayer reservoir
Hallman Pro RX manual boost controller
Walbro 255 lph fuel pump
Buschur Racing ceramic coated SS tubular O2 housing
Buschur Racing Deluxe intercooler
Buschur Racing lower intercooler pipe
Buschur Racing ported single flapper 10.5cm^2 turbine housing
Buschur Racing ported & ceramic coated exhaust manifold
Dejon Tool upper intercooler pipe
Automotorsports (AMS) custom dyno tuned reflashed ECU
With this set up I put down 330whp and 333wtq on Atlantic Motorsports Dynomite Dyno. Boost peaked at 24psi on 93 octane and these numbers were with a tear in my LICP coupler big enough to put my pinky finger completely through. I hope to make over 340whp on the same dyno now that I got all the boost leaks fixed.
After rims and coilovers I plan to go back to the engine for an overhaul including a 20G-LT, meth, studs, BR upper and new lower pipe for IX turbo, intake, mini battery kit, and of course another custom tune. So I will have some stuff up for sale.
Old Mar 9, 2008 | 10:40 AM
personal_golf's Avatar
Veteran: Air Force
Stock Turbo
Hallman MBC at 26-27 Psi
Alcohol
Intake
Evo 9 BOV
93 Octane
HKS Cams
Intake
Perrin TB
Sean Ivey Tuned
Close to 400
1/4: Just under 12
Only the best, Simple and to the point...don't need anything extra or fancy.
wizzo 8's Avatar
I just got mine customed tuned on friday and put down 362WHP and 336 TQ with the mods in my signiture. I couldnt believe it when they showed it to me. AMS has a Dynojet. This is on 93 only with stock turbo
Old Mar 9, 2008 | 10:53 AM
voodooutt's Avatar
AMS cone Intake
AMS Lower intercooler piping
Hallman Evolution RX Boost Controller
Forge recirc BoV
Stock Ported & Polished Exhaust Manifold
10.5 Single Flapper hotside
Megan tubular 02 housing
Helix 3" ceramic coated DP
Works cat delete
Works resonated Intermediate Pipe
Works Muffler Delete pipe
ARP head studs
Tomei Pro 270 Cams
Tomei Springs
Crower Retainers
Walbro fuel pump
317hp / 285tq 93 octane @ 21lbs boost
366hp / 356tq 110 octane @ 29 lbs boost
readings and tuning from AMS
Old Mar 9, 2008 | 10:59 AM
shunderwunder's Avatar
Injen intake
Injen UICP
Speed Source LICP
ETS 3" wide tank intercooler
MIL.SPEC 65mm throttle body
ported factory intake manifold for 65mm inlet
BC 272 / 272 cams
AMS TBE with test pipe
Mynes coated exhaust manifold
PPI ported & coated hotside
Ebay o2 housing modified for open dump (MPFab Dumpatron)
Wallbro 255
AEM tru-boost boost controler
dyno tunded by Doug at TopSpeed
357awhp 322tq
hers the dyno run
http://www.youtube.com/watch?v=6EZXFyGJyac
and the graph
Old Mar 9, 2008 | 11:05 AM
Evo2wIsh4's Avatar
This is pretty much all the bolts ons. I have stock turbo, Stock Heads, Stock Bottom End
The car Dynoed at 373hp and 371tq At Brotherz Racing on pump 93oct
I dont have The new Dyno Numbers With Meth
Ttp Custom Tune
Ttp Methanol Injection Kit
Megan Racing Cat-back
Megan Racing Down Pipe
Megan Racing Test Pipe
Megan Racing Exhaust Manifold
Megan Racing 02 Housing
Ams Copy Fmic
Cosworth 272 M2 Cams
Fidanza Cam Gear
Forge Wastegate Actuator
Hallman Mbc(30psi)
Injen Intake
Injen Upper/lower Ic Pipes
Greddy Type Rs Bov
Act/ttp Hdss Clutch
Act Streetlite Flywheel
Ss Braided Clutch Lines
Zeitronix Wideband/boost/egt/zavt/failsafe
Arp Head Studs
Walbro 255lph Fuel Pump
Hawks Brake Pads
Old Mar 9, 2008 | 12:39 PM
Wow and I thought my engine was the cleanest lol.....awsome work
Originally Posted by shunderwunder
My car is down for a clutch install, so I bit the bullet & ordered everything else I was going to do at once. I will hacve to update this thread in a few weeks when all of the installs are complete & I get dyno tuned. Anyway heres the list of mods.
Injen intake
Injen UICP
ETS LICP
BC 272 / 272 cams
Wallbro 255
will be dyno tunded by Doug at TopSpeed when it is completed
she looks a little naked right now though.
this thread turned out petty good, keep em coming. I see alot of well planned out builds, which is a must when dealing with the God of imports,.....
I forgot to add on mine:
megan header
megan o2 house
10.5 hotty.....
igo4bmx said this thread should be called 10.5 hotside turbos.......why is that? If it is a stock turbo.... it is a stock turbo. Stock means un modified original equiptment..........you could have a 9.8 hotside and still have a stock turbo....
Im trying to read all these and I am getting lost haha in all the mods.....
Old Mar 9, 2008 | 01:07 PM
o-townFLA's Avatar
Talking
316 whp/ 305 tq
ETS 3" front mount
ETS LICP
meagn TBE w/ resonated test pipe
cone filter
forge MBC
tuned @ 21 pounds on 91 octane
stock turbo Evo 9
walbro 255
Tuned @ Tuning Technologies from Alfred
Old Mar 9, 2008 | 01:08 PM
Thanx, I try to keep it clean, but its not easy.
Old Mar 9, 2008 | 01:09 PM
Billy@EnglishRacing's Avatar
i really like this thread, i am a huge fan of the stock turbo, i hate lag
Old Mar 9, 2008 | 01:14 PM
+1. I may eventually do a green & or meth, but for now I want stock turbo on pump.
