Works brain dyno with a/f coming soon
well from my prospective... it looks like the Works flash is very safe.. probably safer than needs to be.. and does exactly what Works has promised. Approx 30 max hp increase.... rev limit increased.. and better air to fuel ratio. I was told that optimal should be around 12 the curve should be flat. 10 and below is too much Fuel not enough air. So 11.5 would actually be safer ratio.. and could be to accomodate for the differences from 1 evo to another. They basically said my stock evo is choking on too much gas
Cool, thanks for the graph TomsSound, Sir Lurks Alot.
To me it seems that the Works flash is running a safer A/F in the lower rpm band than the stock ecu. Which makes more sense to me since this is where the 19psi spike occurs in the power band.
And in the upper band it's still pretty rich. Seems like a good deal to me.
Nice to see Evo enthusiasts getting out there and doing some testing on their own.
Just because we won't post AF/R info, doesn't mean our customers aren't free to do so.
Have fun!
-- DavidV
Have fun!
-- DavidV
Originally posted by Boosted
still sketchy in my book, but oh well
I really like what I see from the a/f and power curves. This is just what I need!! my current car even with the catalytic converters on gives out a really nasty smell at idle (burning too rich) and a lot of black smoke at high rpm (too rich again). I'll give you a call sometime tomorrow David.
Originally posted by Sweft
Different Dyno, Different day. Compare them on the same car / same dyno and it will actually mean something. Now get to the basics..
Works = 850?
Vishnu = 1675?
Get a life heff, stop trolling.
Works = 850?
Vishnu = 1675?
Really though, my sentiments EXACTLY
Shiv from Vishnu Performance dyno tuned a few EVO's at altered Atmosphere...
Here is the link:
https://www.evolutionm.net/forums/sh...threadid=24551
Here is the link:
Here is the link:
Here is the link:
Now using that example it would be easy to run this into the ground as a 16whp and 2ft lb of tq gain is pretty minimal for an $800 + XEDE box. Although this is how a dyno test comparison should be done on the same car, I have to believe that adaptation is possibly a factor here? It just seems like the delta in power is so small, it can't be right?
Now back on topic for the Works re-flash data!
First I have to say thanks to Sir Lurks alot for posting this info. As a Works 93 octane reflash owner, I have been wondering about the A/F for some time. Unfortunately we don't have an AWD dyno in the area yet. The A/F ratios look excellent to me, and are actually safer than I anticipated. I actually thought we might be seeing mid-high 12's(not talking 1/4 mile times either
)which would put it closer to the edge.By comparison guys running an SAFC w/MBC are running in the 11.5-12 range depending on available fuel. It would be interesting to throw a third overlay on that chart to show the same car with an MBC set for say 19 psi. I think thats part of the reason the SAFC guys see pretty impressive numbers is because of the MBC/EBC factor.
Well this will be food for thought for another day, as now we know there is some room to play.Good work David/Works !
N10S
Use the comparison only to comapre the AFR from a Work's Brain reflash to the AFR of a stock ECU.
Do not try and draw any conclusions about 30 max HP performance increases here because measurements were made on different cars. I have seen over 20 HP variances between cars in both stock trim and ones with the exact same mods measured on the same day on the same dyno.
Conclusions about performance increases from the Brain reflash based on this particular graph are useless.
238 max HP on the Work's Brain/muffler delete equipped car may or may not be a reasonable increase. Can't tell without before and after measurements taken from the same car under the same circumstances. My first run for stock baseline on the same dyno was 240.4HP and 251.3 TQ. I'm not trying to compare my baseline with the Works mods (different day, different atmospherics, different car) but just make the point you cannot compare results from different cars.
AFR graphs without HP plot would help prevent the inevitable comparisons that will be made here.
Back to the point, AFR from Work's Brain reflash looks just fine.
jfh- I agree 100% with your comments. If we had a baseline of sir lurks alots Evo in stock trim, we would have the "rest" of the story. As it is the A/F ratio info stands alone and is definitely sound information!
