Anyone Have Oil Light Flickering?
Just wondering if anyone has seen the oil pressure warning light flicker, at idle, after hard driving. I had it happen once, oil level was fine, flickering was gone after I restarted. I'd like to know if its typical or if the sensor needs replacing.
gotten it here same thing happend to me. after a good run with the car may flicker here and there but then checked and everything is good. never had a problem after so i wouldnt be too worried
Check the oil pressure sensor on the oil filter housing for any corrosion. I had this happen to me. Oil light would come on and either stay on or flicker at idle. As soon as you raise the rpm's off idle the light goes out. My sensor connector was corroded and I replaced it along with the sensor. Purchased it from Mitsu for like $26. Repaired issue. GL
Go up to the search ----> Click Advanced Seach ----> Type Oil Light ----> Use the drop down box to select "TitlesOnly" ----> Filter to only forums with EVOs
100's of threads about the issue
thanks, but doing the above gives me two threads, one of which is not really germane.
R U really serious
Here man
https://www.evolutionm.net/forums/se...archid=8071090
2 pages of threads for you reading pleasure enjoy
Simple Computer skills FTW
Here man
If you change it and the light still flickers then obviously its not the sensor.. if your oil level was good, you replaced the sensor.. your light is telling the truth.. then take it in..
mitsumaster
Nov 14, 2015 07:55 AM
evol ways
24
Oct 14, 2008 08:59 PM
