IC Pipe issue!
Old May 21, 2008 | 12:06 PM
tsdchodan's Avatar
That sounds weird. I've been boosting to 25psi for over 2 years now and never had a hose pop off. ::knocks on wood::
Have you removed the pipe before for some reason?
Old May 22, 2008 | 09:53 AM
hellcat's Avatar
Okay, problem solved so far. I didn't have a tbolt clamp or a source for one close, so I took two stock style clamps and put them side by side and used the hairspray trick!! Ill update you guys if this fails. Looks to be holding great at 30 psi.
Old May 22, 2008 | 10:32 AM
Burklow's Avatar
It is a 3" clamp. I bought a t-bolt one from Autozone and it fixed it and has yet to come off again. The stock ones just sometimes don't hold as well as they did when they were new. I don't know how I feel about two clamps, but whatever works.
Old May 22, 2008 | 11:39 AM
mp5999's Avatar
ya, I replaced the stock ones when we changed my ic, no problems since.
Old May 22, 2008 | 11:46 AM
tkklemann's Avatar
Keep in mind too that there IS such a thing as overtghtening a clamp. All Clamps have a torquing spec, just like bolts do, and if you go over, a lot of times it will create a worse situation than under-tightening.
T-bolts are the best way to go because they are usually about 3/4" wide, thus causing about a 1/2" wide bigger sealing surface, and can hold a lot more pressure.
One other thing that will help is to take say a Scotchbrite pad and roughen up the throttle body contact area where the hose will seal against. It will create a "rougher" texture for the rubber hose to grip against, holding it from popping off better.
Old May 29, 2008 | 05:17 AM
hellcat's Avatar
I've had it. Even with two clamps and hairspray under slight boost on the way to work this morning they fell apart again. Im going to put the factory air box back on and see what happens. This never happened before I put the open filter and maf adapter on.
Old May 29, 2008 | 06:09 AM
1wickedEvo's Avatar
No one knows you're pain like I do. I'm sure I've replied to a similar thread awhile back. The first time I heard that pop I knew for sure that my engine was seized..lol Ugh, but I immediately recall a buddy telling me about his UICP popping. So I cleaned it out, tried many things but it would still pop, the last time it popped it was in a dangerous spot so while I was at Turbo Trix I had them custom make me an UICP and they extended my Ultimate racing LICP plus they beaded the end for me. Now I boost with confidence. My route was a bit more expensive, but just like you, I just got fed up and tired of that pop. You might still have that issue with the stock airbox I heard that the T-bolts do the trick.
BTW- I was using constant torque clamps. I also remember someone posting this link as another alternative to T-bolts.
http://www.hrpworld.com/index.cfm?fo...action=product
Old May 29, 2008 | 09:38 AM
ETS Michael's Avatar
A 3" T-bolt clamp will work, but the TB clamp size for perfect fitment without excess exposed thread is a 2.75". The rest of the clamps for the UICP connections are 2.5". Hopefully that helps someone
Tom
Old May 29, 2008 | 10:42 AM
atomicapples's Avatar
i had the same problem, and even with a tbolt, it still popped off... running 24psi...
i just ended up buying a whole upper intercooler pipe... with better couplers...
Old May 29, 2008 | 11:53 AM
mksevoix's Avatar
i had the same issue i ended up saying screw it and buying upper and lower intercooler pipe kit from ams with the small battery kit prob solved.
TEXAS TRAVISTY
Outlander Sport
58
Feb 25, 2021 05:48 PM
ohnah
Feb 23, 2013 11:35 PM
ChrisVIII
Jan 30, 2012 01:35 PM
stevolution84
36
Nov 20, 2011 08:09 PM
.MM
Apr 3, 2010 11:19 AM
