30,000 Maintenance...
Old Jun 20, 2008 | 01:42 AM
MTRJunior's Avatar
Hey guys,
I lost my maintenance book for my car...but I'm due for the 30,000 mile maintenance. Could someone on here list everything that's included in that (under severe maintenance schedule)? I called the dealership and they told me it would cost 600 bucks for 30,000 mile maintenance and they would need the car for 4 hours...should it really cost that much?
Old Jun 20, 2008 | 05:47 AM
JakeTheVIII's Avatar
No! Don't do that. Do it yourself if you can. Just dug mine out and heres the 30k maintenence:
-Check fuel system for leaks(tank, pipe line and connection, and fuel tank filler tube cap.)
-Check condition of fuel hoses
-Replace air cleaner filter
-Replace drive belts (for generator, water pump, power steering pump)
-Check and service exhaust system(connection portion of muffler, muffler pipes and converter heat shields)
-change oil
-oil filter
-change manual transaxle oil
-change transfer oil
-check reserve tank fluid level(for ACD)
-change coolant
-Inspect coolant hose condition(radiator and heater hoses)
-Inspect rotors/pads
-check brake hose condition
-Inspect ball joint and steering linkage seals for grease leaks and damage
-Inspect suspension (looseness and damage)
-Inspect driveshaft bolts
-change rear axle oil with limited slip diff.
-rotate tires
-Replace air purifier filter
Basically just change your engine oil and filter, your transmission oil, and your transfer case/differential fluid. Keep up on your brake pads(Hawk HPS are cheap). Make sure nothing's leaking and check over the obvious stuff. Should be good to go!
Old Jun 20, 2008 | 05:49 AM
Or, I can do it for $599 in less than 4 hours!!
Old Jun 20, 2008 | 06:49 AM
PHDoc19's Avatar
I'll do it for $598.99 in three hours
Seriously, you can do all of this stuff yourself. There were several discussions going around a few weeks ago about fluid changes. That is really the most intense (and expensive) part, but it's not hard.
Old Jun 20, 2008 | 08:24 AM
subaruwrx420's Avatar
How about changing the accessory belt? I don't think there is any info about it. I understand that having a special pulley loosening tool really helps. This is the only thing I have not done on the 30k service. Just seems like a real pain with about a inch of space between the frame and the motor...damn transversally mounted engine
llckll
Lancer Engine Tech
Mar 22, 2011 08:07 AM
wsquare
Lancer Engine Management / Tuning Forums
Apr 11, 2009 03:35 PM
GeneticDrift
Nov 22, 2008 06:01 AM
USMCEVO
10
Feb 27, 2007 03:44 PM
DefBringer
Midwest Region
Dec 19, 2005 08:27 AM
