Car won't start..EVO7
Old Jul 7, 2008 | 10:48 PM
rh9's Avatar
rh9
Originally Posted by 1d10t
Its not a fuse because the cars' electrical circuits are load to ground. You shot voltage the opposite way (electron theory LOL!). The ring antenna is on the steering column, and on US model evos (LHD) the immobilizer ecu is located to the right of the steering wheel behind the center console of the dash ( Near DLC), but I'm not going to tell you how to surpass it.
If power is present at pin 7( L/Y evo 8) and pin 9 (L/W) the ecu may be toast. If no power present futhur diag required. Good luck
Does the engine crank when the key is turned?
Pin no.7 and pin no.9 ??? On the ecu ? no7 is an empty pin, no.9 is emissions bs, unless you're talking about these pins somewhere else other than the ecu
Yes, the engine cranks, It'just that the power fc doesn't light up(commander) so obviously no spark, no fuel,
Ecu can't be toast, cuz the stock ecu doesnt start it either, neither does it make spark
Old Jul 7, 2008 | 10:51 PM
rh9's Avatar
rh9
Did you check the fusible link?
Also the Immobilizer ecu could cause power issues the the pcm, but also check the MFI relay. Good luck
Which fusible link ? where is that ?
MFI relay ? sorry but I haven't really worked on the evo to get that deep, now i am
Old Jul 7, 2008 | 11:57 PM
rh9's Avatar
rh9
Is that mfi relay one of the two black relays hanging behind the strut bar on the firewall ?
Old Jul 8, 2008 | 03:12 PM
rh9's Avatar
rh9
anyone ?
The car is sitting, i ran outta ideas
Cody Parrott
Lancer Troubleshooting
Jul 10, 2024 08:41 AM
DecBro
May 17, 2017 07:14 AM
newblancer
Lancer Engine Tech
Jul 1, 2016 09:35 PM
Luckiesralliart
Nov 29, 2012 09:51 AM
williams12
Jul 10, 2012 05:07 PM
