Weird issue with ignition hole.
Old Jul 10, 2008 | 03:52 PM
Inflation's Avatar
Okay so I know the title sounds a little weird but here is my issue. About 6 weeks ago my starter got stuck. I would but the key into the ignition but it wouldn't turn no matter how hard I forced it. I had to get a pair of needle nose pliers grab onto the key and tug. It finally moved and I could start the car. ( it bent the key a little). Then it is fine for about 3 weeks and it did it again so I fixed it the same way. Now 3 weeks later it happend today. Fixed it the same way my key is still kind of bent. Any ideas of what this could be? I don't want to break my starter but I had to do it to get to work.
Old Jul 10, 2008 | 04:24 PM
Vivid Racing's Avatar
How long have you had the Evo? This is common on some other cars... it could be pocket lint... When you have your key in your pocket and pull it out it may have pocket lint on the key. After a while it jams every thing up. Try spraying a small amount of WD40 on the key and turn the key several times. If not pull it all out and clean it up.
GL
Evan Smith
bso's Avatar
bso
I had that happen to me on a Honda Civic. Your key is worn out at the grooves and you need a new one made. If the key is the only one you have, than will you need to have the car re-programed at the dealer. Otherwise, do a search on reprograming keys for an Evo 8.
Old Jul 10, 2008 | 04:31 PM
^^^ That happens on the honda a lot, It could have happend here too, but it would be weird for his key to rub down so quickly
Old Jul 10, 2008 | 04:59 PM
Inflation's Avatar
I have two keys and I have the issue with both so I'm going to try wd40 if that dosen't work then I'm just going to pull it all out. Would compressed air do anything?
Old Jul 10, 2008 | 05:49 PM
1d10t's Avatar
when this happens its usually the lock cylinder. Hopefully in your case its not, but as a tech, its usually the lock cylinder
Old Jul 10, 2008 | 06:04 PM
Inflation's Avatar
How much would that cost to fix?
Old Jul 10, 2008 | 06:07 PM
1d10t's Avatar
depends on the shop. the lock cylinder is, of course, vin specific.
Old Jul 10, 2008 | 06:49 PM
bso's Avatar
bso
Any problems opening the trunk or the doors with the key?
Old Jul 10, 2008 | 06:55 PM
Inflation's Avatar
No not at all just turing the ignition.
Old Jul 10, 2008 | 07:02 PM
skold's Avatar
sounds like you have the steering wheel in the lock position, happens at lexus alot
Old Jul 10, 2008 | 07:58 PM
jd323's Avatar
As other have said, it seems it could be a ignition tumbler problem.
Old Jul 10, 2008 | 08:09 PM
EatSleepBoost's Avatar
yea lock cylinder is now probably ruined since uv forced it a few times.
rallyjr27
Nov 2, 2015 08:11 PM
wazzelby
Jul 18, 2015 05:46 PM
shaffner666
Lancer Troubleshooting
Jun 20, 2014 05:31 PM
umopp
Jun 22, 2012 12:27 PM
