Launch Control problem
Old Sep 20, 2008 | 06:20 PM
darcnytemare's Avatar
Originally Posted by jpetro10
there is a little pin that the clutch pedal pushes in when depressed, attached to the pin in a sensor or something, sometimes this can come unplugged. Check that, quick question, can you start your car w/o pushing the clutch in?
my boy has a IX and he starts his car with remote start. maybe it was disabled. but i thought it was illegal to be able to start the car with out the clutch in. cause some people have left it in gear and the car jerks forward
Old Sep 21, 2008 | 01:26 PM
brandEvO's Avatar
cannot start the car without pushing in the clutch
Old Sep 21, 2008 | 01:41 PM
Duh Panda's Avatar
yes you can ........
i can do it with mine so can many others....
Old Sep 21, 2008 | 04:02 PM
Duh Panda's Avatar
Originally Posted by abraxas
Yeah, but not without doing some sort of flash/mod, right?
mod? sort of... just with the clutch pedal
Old Sep 21, 2008 | 04:04 PM
jpetro10's Avatar
i can right now, I think....but not sure, all you do is unplug that sensor by the which the clutch pedal pushes down. Correct me if im wrong though, Ive always been able to start it w/o pushing it in and my sensor has always been unplugged.
Old Sep 21, 2008 | 04:07 PM
Toxin's Avatar
Em... Put it into neutral and start it up? Why wouldn't you?
Old Sep 21, 2008 | 04:08 PM
rob17san's Avatar
i can do it to
Old Sep 21, 2008 | 04:10 PM
Oki Panoki's Avatar
Originally Posted by lemmonhead
you have to be on a flat surface. Anykind of incline will disable it.
not entirely true, ive done mine on hills before kinda with a heal toe method and it still works
Old Sep 21, 2008 | 04:15 PM
Duh Panda's Avatar
same concept.. if you roll back the slightest bit it will disengage
big fooot *** having mo fo...
Old Sep 21, 2008 | 04:17 PM
Oki Panoki's Avatar
and to answer the clutch pedal start thing. any manual transmission car has a sensor on the clutch pedal that tells the car if it is in all the way or not. simply so you dont start the car while it is in gear, this is bad for many obvious reasons. in our case, if u unplug the sensor you can start the car without the clutch being depressed. this works in other cars as well but in some states may be illegal because the whole thing about remote starters...
edit: however this sensor does not come into play at all when using the launch control. you can do it in neutral is what i mean
Old Sep 21, 2008 | 04:22 PM
Oki Panoki's Avatar
Pyam
Mar 19, 2017 09:44 PM
Ralli_Red
13
Aug 20, 2015 07:57 PM
CGMSTI
Jun 1, 2014 05:22 PM
08 Evo X MR
Oct 3, 2013 10:41 AM
nshen43
12
Mar 12, 2012 10:30 PM
