What is this part?
Old Oct 8, 2008 | 11:47 AM
goucho's Avatar
What is this part?
Ok, so last weekend at autocross I "apparently" dropped this part off my car. Although I think that this part is from another car and nobody noticed till i ran it over, since it was in the rain.
I checked both the front and back lower sway's and struts, and their still there. Also, this bar is pretty chincy and thin, so I don't think it would be part of my car. But i want to verify so I can be sure.
Dimensions:
25.5" Length
1" x 2" End Tab dimensions (flat part)
0.75" Diameter
Old Oct 8, 2008 | 11:51 AM
Billy@EnglishRacing's Avatar
it is a lower tie bar that alot of people take off there car for downpipe fitment
Old Oct 8, 2008 | 01:32 PM
IMPdemon's Avatar
Yep, that's your tie bar.
To clear the dp, the prev owner on mine used washers as spacers at the mounting points. But even so, the dp would flex enough that it would contact and transmit a weird rattle up through the cabin.
I finally decided to take mine off after I was traveling down a dirt road, and big rocks on the crown of the road were "plucking" the tie bar, and sounding like a huge guitar string. The K member looks beefy enough w/o it, so I'm not worried.
What I'm wondering is, how did yours come off? Is your evo lowered? Did you drag any cones?
Old Oct 8, 2008 | 01:37 PM
EvoBroMA's Avatar
HAHAAH this thread is hillarious. how did you lose it?!
Old Oct 8, 2008 | 02:10 PM
IMPdemon's Avatar
In fact, here you go, straight from the FSM.
Old Oct 8, 2008 | 02:30 PM
porsherules911's Avatar
check underneath to see if you have your tie bars.
Old Oct 8, 2008 | 03:42 PM
goucho's Avatar
Awsome! Yeah, I hadn't got a chance to really investigate where it might have come from. I just briefly looked underneath.
As far as how it came off, I have no idea. Although I do have one theory (and no I didn't drag a cone, i avoid them )
I think that when I took my car to AMS and they put on the TBE, they had to take the Tie Bar off, right? So maybe when they put it back on they didn't tighten it down all the way. Since I autocross A LOT, it probably shook loose and eventually shot out the car while racing.
IN FACT, this is exactly what happened with my battery. The negative terminal came loose after a morning of autoX. This was after AMS did the work to my car and I had not touched it since.
So I'll just have to put it back on and torque it to spec. Thanks for the feedback!
Old Oct 8, 2008 | 03:46 PM
cthcky5's Avatar
lower tie bar
Old Oct 8, 2008 | 04:21 PM
yeah if they changed your downpipe then they had to take them off.
goucho
Nov 23, 2013 05:48 PM
goucho
Pacific Northwest
Mar 8, 2012 11:21 PM
goucho
Nov 26, 2009 11:43 AM
goucho
Jun 24, 2008 10:10 PM
Evolento
Jul 10, 2007 10:16 AM
