Quick EVO Ballast Question
Old Nov 14, 2008 | 09:55 PM
xLaNcErEvOx's Avatar
I have an evo 8 with HIDS from factory and the driverside ballast went out, are both the driver side and passenger side ballast interchangable??? Are they the same ballast in everyway?
Old Nov 14, 2008 | 09:56 PM
partyboy1122's Avatar
Yes they are the same ballasts.
Old Nov 15, 2008 | 08:21 AM
i checked and the connector part of the ballast is different, i cant seem to get the plug to fit...???
Old Nov 15, 2008 | 12:59 PM
oneofakindtrini's Avatar
exactly wht's a BALLAST?
Old Nov 15, 2008 | 01:01 PM
fugiwara's Avatar
it's the box under neath the headlight
Old Nov 15, 2008 | 03:20 PM
Diggler's Avatar
They are definitely the same. I just changed my passenger side unit and swapped side to side to verify the ballast was the problem.
Old Nov 15, 2008 | 03:23 PM
wevo1985's Avatar
make sure the bulb isnt bad
Old Nov 16, 2008 | 12:11 PM
EvoIXMRSEPilot's Avatar
http://www.plasmagarage.com/HIDballast.html
Read. Learn.
Old Nov 16, 2008 | 03:09 PM
thx.
Old Nov 16, 2008 | 04:33 PM
no prob bob.
Old Nov 16, 2008 | 06:21 PM
Billy's Avatar
Are you the original owner? Maybe a previous owner replaced one?
If you take a picture of these connectors and post them up, someone might be able to confirm.
Old Nov 16, 2008 | 06:27 PM
BBYBruno's Avatar
I thought my ballast went out also because one of my headlights started turning a purple color then started flickering and would turn off. But it was just the bulb.
Old Nov 16, 2008 | 07:35 PM
im the original owner. ill try to take a pic if possible
x_EvoChick_x
Mar 18, 2026 06:39 AM
Kevin Guzman
Evo X How Tos / Installations
Jan 28, 2017 07:48 AM
mister1161
Sep 25, 2015 12:46 AM
Johnx972
Nov 4, 2013 09:04 AM
old G
Jun 20, 2013 10:05 AM
