Mounting Spot for Greddy Turbo Timer
Old Nov 15, 2008 | 11:56 PM
MTRJunior's Avatar
Hey guys,
My 16yr old brother just have me a Greddy Turbo timer for my bday! ...so I'm thinking of spots where I could mount it...I want to do something a little different instead of just mounting it on top of the steering wheel. Do you guys have any pics of where you mounted your Greddy Turbo Timer?
...I've been thinking about getting rid of the clock and mounting the turbo timer in there...has anyone here ever done that before? If so, did you have to cut anything or was it a perfect fit?...does anyone have a tutorial on mounting the turbo timer where the clock is?
Let me know...
Thanks
Old Nov 16, 2008 | 12:11 AM
bluebanana23's Avatar
ash tray or above your right knee is
Old Nov 16, 2008 | 12:42 AM
ineedspots's Avatar
i have mine right above the ash tray right below where the
empty spot is, although some people have radios there...
im not sure about you but mine looks clean and its in a good
spot where i can see and make any adjustments needed just
used some outside double sided tape
Old Nov 21, 2008 | 09:36 PM
MTRJunior's Avatar
what kind of double sided tape did you use? I just bought some "heavy duty" ones at walgreens for 5 bucks and it doesn't ****ing stick
Old Nov 22, 2008 | 05:59 AM
killthelights14's Avatar
lol above the ash try is a ***** to get it to stick. i dont know why. I have used all types of tapes, velcros...ect. After a week or so it would just fall off and unstick.
Old Nov 22, 2008 | 08:11 AM
joon82's Avatar
lol i did same thing. I spent over 20 dollars on different kind of tapes and failed. So just leave it on the carpet.
Old Nov 22, 2008 | 08:14 AM
mx4life85's Avatar
Thats why I had to use some caulking ****. It sticks so good, it just sucks because you can see the glue still....but its stuck on there for good now!
Old Nov 22, 2008 | 08:53 AM
joon82's Avatar
I tried so many different tapes but all failed to do their job in Texas weather.
Old Nov 22, 2008 | 01:13 PM
19DB794's Avatar
I have mine mounted under the factory gauges. I used double sided tape and that didn't work to good so instead I used velcro and it worked better.
Old Nov 22, 2008 | 01:27 PM
chaotichoax's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=203519
I'm sure you can find some ideas there...
Old Nov 22, 2008 | 09:31 PM
compscibOi's Avatar
I had mine below by the ashtray. If you push it back will just be wedged between behind the ashtray and the bottom of the radio din perfectly.
I recently installed some Defi gagues, so I had to relocate my turbo timer. I moved it up where the clock used to be. The timer will not fit perfectly, so I used a dremel and filed both sides, until I could wedge the timer in where the clock used to be. Looks dope now!
I didn't want it on the steering wheel as that looks stupid IMO and I have my Zeitronix mounted there, so it would block my view of it.
Old Nov 22, 2008 | 10:00 PM
jmcevo1's Avatar
mounted mine to left of the steering wheel roght above the dash fold looks great highly recomed it!!
Old Nov 23, 2008 | 03:11 AM
MTRJunior's Avatar
I have both my greddy turbo time and electronic boost controller now installed and sitting right next to each other above the ashtray wedged at the bottom of the radio din...I want to have it taped to the radio din so it's facing up and easier for me to read...but I bought double sided tape and it won't stick to the plastic of the radio din, should I even try the velcro?
Old Nov 23, 2008 | 05:49 AM
joon82's Avatar
Velcro was better than 3m double sided tape. It might work for you but didnt work for me due to hot weather in Texas.
Old Nov 23, 2008 | 06:45 AM
donmeca2020's Avatar
yeap same here, mines wedged between the cubby and the console. no need for tape it fits pefectly
