How To: Modding your Evo ~$100 at a time!
Old Nov 30, 2008 | 09:03 AM
  #91
prodystopian's Avatar
Originally Posted by S2kracka
The Joe P. is my personal favorite manual boost controller. Its cheap, effective, and reliable. ECU controlled boost is nice in the fact you can log your boost level (with a 3-bar MAP sensor) and it will allow you to run more boost at redline. I'm personally on ECU-controlled with a GM BCS and Evo X 3-bar MAP sensor which I switched to from a Joe P. If I were to build another Evo I would stick with the Joe P. though since its a lot cheaper and so much simpler. Less dinking around and it just plan and simple works.
As for the benefits of the vents, my friend who logs all of his gas mileage noticed an increase, we both noticed a smoother idle, throttle response definitely was improved, and in addition to these things my S2000 went from using 1.5 quarts of oil between changes to using absolutely none no matter how hard I drove it.
Thanks for all of the info. If you went with just the Joe P. though, how would you tune the boost? Wouldn't you still need a new sensor (for an Evo VIII) to log the boost?
Old Nov 30, 2008 | 09:29 AM
  #92
Kracka's Avatar
If you are using a MBC you need to watch the boost gauge or buy the Evo X MAP sensor to log it through the ECU.
Old Nov 30, 2008 | 10:55 AM
  #93
MikeyT's Avatar
Originally Posted by bluebanana23
sticky this for the noobs who ask what mods to do
+1 for noobs like myself. glad I saw this thread. very helpful!
Old Nov 30, 2008 | 10:22 PM
  #94
headrec's Avatar
Great guide. Thanks for the contribution!
Old Dec 7, 2008 | 02:14 AM
  #95
doobie's Avatar
awesome post. bump
Old Dec 7, 2008 | 04:59 PM
  #96
Kracka's Avatar
Added some info/links for the Beatrush driveshaft and rear differential mount bushings!
Old Dec 7, 2008 | 05:10 PM
  #97
Evolution IVGSR's Avatar
Well done man
Old Dec 7, 2008 | 08:34 PM
  #98
EvoIXMRSEPilot's Avatar
thank you for a comprehensive list.
Old Dec 7, 2008 | 09:47 PM
  #99
MR_Lance's Avatar
great info. subscribed!
Old Dec 7, 2008 | 11:26 PM
  #100
merlin00069's Avatar
Good write-up
Old Dec 8, 2008 | 07:11 PM
  #101
Kracka's Avatar
RS trunk bar info added!
Old Dec 11, 2008 | 08:52 PM
  #102
Bster13's Avatar
Thanks.
Old Dec 11, 2008 | 09:01 PM
  #103
Bster13's Avatar
Did I miss a tip on O2 housings in this thread by chance?
Cheapest I've seen is the TTP O2 housing for $100, but I have no idea what is the best bang for buck performing O2 housing...thoughts? (figure this mod would fall into the $100 range.)
Old Dec 11, 2008 | 09:11 PM
  #104
abazaba410's Avatar
i hear a lot of good things about the Megan O2 housing n I got mine for 95 bucks. Just havent installed it yet
Old Dec 11, 2008 | 09:12 PM
  #105
Bster13's Avatar
Linky please abazaba410....
