my antenna broke
Old Dec 13, 2008 | 03:32 PM
deegaw11's Avatar
my antenna broke
My antenna somehow broke off at the car wash yesterday, I don't know how. Maybe due to the cold weather, but the bolt is now stuck in the screw hole and there is no way i can unscrew it out. Now my radio constantly has static, Is there anyway I can take that piece out the hole?
Old Dec 13, 2008 | 03:46 PM
Speed Corps's Avatar
Former Vendor
Is there enough of the bolt left where you can use a small drill and drill a hole in it? You can go to any hardware store and get an easy out. Once you drill the hole, you put the easy out in it and screw it out.
It would be similar to this:
http://www.speedcorps.com/boltdrill.html
adamweldonjohns's Avatar
try the ol' potato in the light bulb trick yet???
Old Dec 13, 2008 | 04:53 PM
EvolNinja's Avatar
Don't they have warnings about antenna when you take your Evo for a wash? Anyways, I took mine a couple times and it's fine but that's in the summer I usually wash it myself during the winter. Good Luck
Old Dec 13, 2008 | 06:02 PM
deegaw11's Avatar
What trick is that?
deegaw11's Avatar
how much would a shop charge to take it out?
Old Dec 13, 2008 | 07:12 PM
huevosrancheros's Avatar
Do what I did, sway out your antennae for a Honda Element one.
Old Dec 13, 2008 | 08:30 PM
thatguy's Avatar
My antenna snapped off and broke my antenna base. Piece of crap!
Old Dec 14, 2008 | 01:03 PM
Same way you get a light bulb out of its base when its broken off down low - take a potato, push it against the part (like the sharp glass in the bulb) and turn it like you normally would - usually works awesome for a lightbulb, maybe it'll work for the antenna.
Old Jan 11, 2010 | 04:02 PM
law418's Avatar
So how did you fix it at the end? Same thing happened to me and I broke the base when I was trying to drill that bolt out.
Old Jan 11, 2010 | 04:11 PM
5LEEPERISAH23I's Avatar
deff to much money...
Old Jan 11, 2010 | 04:37 PM
revvin9k's Avatar
The thought of someone sitting outside in cold weather smashing a potato to the roof of their Evo made me lmfao. That trick will not work.
Drill it and use an easy out as mentioned above. If you have never done it before, take it some where so you do not make it worse. GL
EDIT: Reading post dates ownz me.
Old Feb 9, 2010 | 12:20 PM
cash's Avatar
lol thats a good trick ahah but i dont is efficient
Old Feb 9, 2010 | 12:41 PM
mifesto's Avatar
drilling it is possible to get it out but another method i've seen work is to glue another piece to it then turn. antennas arent torqued high so it should work. scuff the broken surface and clean it so its ready for superglue to adhere. then stick a small metal tab to it, let it sit overnight. carefully turn next day and i bet it will come out.
Old Feb 9, 2010 | 12:49 PM
05blue8's Avatar
What mifesto said. My sister's biss screw was stripped out on her old 93 galant so I put a few drops of super glue on a screwdriver and rested it against the top of the screw. After holding it so it sit on straight for about a minute it was stuck good so I was able to slowly unscrew it
Good call mifesto
buzzzin_IX
May 21, 2015 10:28 PM
harp12
Sep 18, 2014 07:10 PM
Hittman
Jan 26, 2008 03:36 PM
Eggy
Dec 12, 2006 07:32 PM
Smoku
May 4, 2006 10:12 PM
