Harness bar vs. Roll Bar?
Old Jan 29, 2009 | 12:08 PM
-Evo Aaron-'s Avatar
hello everyone i was wondering if there are any safety issues in regards to getting a harness bar, vs a roll bar, i no that obviously roll bar would help if the car rolls, and would be more stable than a harness bar, but anything else?
Old Jan 29, 2009 | 12:29 PM
xtnct's Avatar
Using a harness bar usually leads to using a racing harnesses (5 or 6 pt) that should not be used without a roll bar & racing seat.
Instead, either get a roll bar so that you can use the correct harness, or use a belt that is designed to be installed without a harness bar utilizing the stock mounting locations - such as the TUV & DOT approved Schroth with ASM harnesses.
Both a roll bar and harness bar make the rear seats unsafe for rear passengers, even if people put foam around it. For best human protection, you should be using the expensive dense stuff (like this: http://www.pegasusautoracing.com/pro...p?Product=2391), not the cheap foam stuff (like this: http://www.pegasusautoracing.com/pro...p?Product=2390).
Old Jan 29, 2009 | 12:32 PM
2006blkevo9's Avatar
Well a harness bar is just that, a place to connect your harness. It gives a little more rigidty to the car but not as much as a roll bar would. And with the harness bar a back seat passenger wouldnt really be all that safe (There is another tread about that on this forum).. They really are both for off the road driving, not really needed for street driving, but hey they look nice..
Old Jan 30, 2009 | 11:10 AM
Wicked White's Avatar
If you want to start racing seriously, I'd look into getting a full roll cage. If you're just looking to stay in your seat better, get a racing seat and call it good. Harness bars are pretty cheap though.......cheaper than a seat. So it's up to you.
Old Jan 30, 2009 | 04:37 PM
armaniranger's Avatar
like some people have already said a roll bar is for roll overs of coarse but if you do get a harness bar and have a accident where you end upside down, you could get hurt when using harness and no cage or roll bar.
Old Jan 30, 2009 | 04:43 PM
sspaladin28's Avatar
Wow, great question and good answers. Learned some new stuff today!
Old Feb 12, 2009 | 12:08 PM
blkmkIII's Avatar
id do a harness bar.
Old Feb 12, 2009 | 07:50 PM
juzdyn's Avatar
If you're doing strictly street racing then you don't even need them. I wouldn't get a harness because i think its a waste of money, I'd rather save a little more and just do a roll bar.
Old Feb 13, 2009 | 06:10 AM
Robevo RS's Avatar
roll bar never hurts.
Old Feb 13, 2009 | 06:21 AM
05ah8james's Avatar
I'm putting a harness bar in my car as an excuse to not carry people around in my car anymore .
Old Feb 13, 2009 | 08:51 AM
juzdyn's Avatar
Thats a good point...i'd do the same but it CAN get really inconvenient.
Old Feb 13, 2009 | 08:56 AM
CaliMR's Avatar
Do neither for a street car. If you put a roll bar, do not drive without a helmet. If you do a harness bar, do NOT put anyone in the back seat, because if you get in an accident then they will hit the bar and die and you can be prosecuted for murder (under the reckless disregard for human life theory). You can get a removable harness bar, but you really don't want a harness bar without a roll bar in case you flip. And never use a 4 point harness unless it has anti-dive, or you can submarine and that is some you really don't want to do. I have seen most of this stuff happen, and the mess it makes is not pretty.
Old Feb 13, 2009 | 12:50 PM
juzdyn's Avatar
a removable harness is only good for using it as a weapon in a roadrage argument no seriously, you don't need anything like the dude said, unless you are seriously that hardcore, then i'd tell you, go to racing school instead so you can avoid flipping :P
Old Feb 14, 2009 | 11:33 AM
Thanks guys, I decided not to get it, learned some great info, I guess it's very unsafe for the driver and rear passengers and I don't want that, I guess on track days I could just hook up the harness to the factory bolts in the rear which are for the child seats?
Old Feb 14, 2009 | 02:57 PM
xtnct's Avatar
Definitely NOT!!!! https://www.evolutionm.net/forums/mo...er-anchor.html
If anything, only the stock adult rear seat belt anchors.
