Tail Lights/ Plate Lights/ Markers lights... Help Please
Old Feb 12, 2009 | 03:29 AM
armaniranger's Avatar
well if you know the marker is flickering i would just start with that one since it seems to be doing the most... then go from there
Old Feb 12, 2009 | 06:43 AM
gsrboi80's Avatar
Likely in the kick panel harnesses man. The fact that you said when it rains
See here
https://www.evolutionm.net/forums/in...lins-rain.html
Old Feb 12, 2009 | 07:23 AM
binarysleep's Avatar
Do you know how to use a multimeter; or more specifically how to check for continuity between a wire a chassis?
Remove the bulbs from the circuit and check for continuity between the positive wire and chassis ground. If you get any continuity, then you have confirmed a short somewhere. The problem is, if you only have problems when it's wet, you will probably only find the short when it's wet.
You are going to have to trace the short circuit down. Use the diagrams I attached and slowly work your way from the tail light housing to the front of the car checking each connector for continuity between positive and chassis ground. This could take 5 minutes, or half a day.
Attached Thumbnails Tail Lights/ Plate Lights/ Markers lights... Help Please-tail-light-circuit.bmp   Tail Lights/ Plate Lights/ Markers lights... Help Please-splice-locations.bmp
Old Feb 12, 2009 | 04:38 PM
Sansone's Avatar
Thank you! Ill definately have to check those connectors in the rear bumper. When the snow around here gets deep and slushy, the back bumper scoops it all up inside by those clips most likely. This even causes my rear bumper to sag. Am I missing a skid plate of any sort back there?
Once again thanks!
Old Feb 13, 2009 | 09:04 AM
There is no factory skid plate/underpanel for the rear. You can buy an aftermarket one. It is reported to help aerodynamics at higher speeds and improve fuel economy too.
You might consider spraying water up under there if you want to reproduce the problem for troubleshooting.
Old Feb 13, 2009 | 10:13 AM
mplspilot's Avatar
See here
Sansone,
This is the answer right here. Trust us, man. I had the exact same issue with right taillight and interior lights going out. If you don't fix those harnesses by the driver kicker panel your problems will only get worse.
Old Feb 13, 2009 | 05:41 PM
Sansone's Avatar
See the thing is I did look at that harness and the ones around it. They were fine. I even sealed the hole with duct tape afterwards and dried every clip out just incase with a blow dryer. The last time I threw another 7.5a fuse in there, the tail light faded in an out a bit, smoked for a second and blew the fuse. Wires are still fine, but still..........
Old Feb 19, 2009 | 05:14 PM
Sansone's Avatar
Should I just solder the wires and eliminate the clip?
Old Feb 25, 2009 | 09:10 PM
Sansone's Avatar
Found the short boys! Nice weather came today, followed all of the wiring and.... it was the damn side marker light.(figures it was just that and here I am freaking out) The connection was corroded as hell, the power wire popped out and was grounding out. Fixed, drove it in the rain and no problems.
Old Feb 25, 2009 | 09:11 PM
Sansone's Avatar
P.S- the hole in the fender is now sealed, better safe than sorry!
1LSTRDE
Apr 4, 2024 10:45 AM
shawn360h
Oct 28, 2016 01:16 PM
Levee06
Jul 17, 2014 12:33 PM
tazz33
Mar 23, 2014 07:08 PM
i.Apotheosis
Lancer Troubleshooting
Mar 27, 2012 07:07 AM
