not going to believe what mitsu dealer did
last night was driving home and when i got home noticed there was a trail of oil leading to my garage i lift up the car and everything is soaked in oil. i remove the oil filter and i notice that there are two o rings and one of them failed. Mitsubishi was so careless leaving two o rings on the car.
how long did you drive? if you fixed it yourself you should be good...when i built the motor on my car...it was so time consuming and pain staking that when i finally filled her up with oil, I forgot to tighten my drain plug and started the car in the garage. Got lost about a half a quart...now its triple check everytime i do the oil lol
wow that is alot of oil lost, I would get some type of documentation, so if you motor happens to spin a rod bearing you can maybe get a new motor.... what dealership in arizona was it?
I've done this before. Most of the time, the oil ring stays attached to the oil filter when you take it off. I didn't notice this and just put on a new one. I lost about 5 quarts of oil in my eclipse. Most expensive oil change I've ever done. I wouldn't be hard on the guy who did it. Its a rare thing that happens.
the dealership on bell and 12th street, hopefully they extend my warranty because i really don't want to replace a motor on my bill
doesnt surprise me. the last time i was at the dealership they disconected my battery.. and never reconnected it. i found out 20 mins later when i parked a for a few mins and my car wouldnt turn back on.
make sure you get over there and get everything checked out, and get their mistake in writing.
