Headlights Out of Alignment?
Old Mar 13, 2009 | 03:21 PM
BoostLover99's Avatar
Driving at 65 mph at 3 am on I-15 feels as if I'm driving too fast for the headlights; they seem to be out of alignment as I distinctly remember being able to drive at least 70 mph on I-15 at 3 am less than 6 months ago.
Looking at the beam pattern, it looks as if the headlights have been "pushed" down & out (away from vehicle's front to rear center line) for some reason.
The manual leveling is at its highest setting and still works; lowering the lights using the leveling feature makes the problem worse.
Does anyone else have this issue? How did you resolve it?
Car is 2006 MR, has factory lights (HID project lowbeam, Halogen high beam).
And no, I'm not old - I'm not even 30 yet.
Old Mar 13, 2009 | 03:23 PM
idriveanevo's Avatar
just use a screw driver to raise the light, have you lowered it since then?
Old Mar 13, 2009 | 03:33 PM
eyekyu's Avatar
mess with the 10mm bolt in the back of the headlamp
Old Mar 13, 2009 | 05:13 PM
How do you know when the alignment is correct?
Trial & error at night?
How do you correct the horizontal alignment?
I don't want to be the idiot on the road blinding everyone else - I'm looking for some sort of objective way to restore their alignment to factory specifications.
Old Mar 13, 2009 | 06:31 PM
2.0Ldoom's Avatar
there is a proper way to do it, I am not 100% but you need a wall (like the back of walmart) back up 25 feet and there is a certin height they should be from the ground there should be a how-to some where....
Old Mar 13, 2009 | 11:30 PM
Ok - thanks!
Old Mar 14, 2009 | 01:08 AM
sikwititevo9's Avatar
just park about ten or fifteen feet away from a wall and align them to be about level with the lights on the car then just drive around and adjuste them from there its way better at night of course
Old Mar 25, 2009 | 09:42 AM
Sievers's Avatar
I just pull up to my garage door and adjust. basically what sikwitit said
tiesto14
14
May 19, 2016 08:52 PM
Mweisel
Jul 23, 2015 07:52 PM
BULLETEVO
Jun 12, 2014 09:29 PM
AMSTuning.com
May 4, 2010 04:17 PM
Jason05RS
Dec 3, 2008 10:09 AM
