Wing Removal ???
Old Mar 23, 2009 | 03:16 PM
pcamara17's Avatar
Wing Removal ???
I went to my buddies body shop and I am getting my cf recoated but he told me to remove the wing off for him but the only problem is I want to know what is the right way to take it off before I start tearing **** apart, I checked on how to installation link and could not find how to take it off. Anyone please help?
Old Mar 23, 2009 | 03:21 PM
chaotichoax's Avatar
you'll need a deep socket and a wrench...a hair dryer (to heat adhesive under wing)
and that's about it
Old Mar 23, 2009 | 03:22 PM
sikrsix's Avatar
Normally Id say SEARCH!!! But since this site is back to its old design the search feature blows!!!
I knew i helped someone else with this and it still took me 15min to find it.
https://www.evolutionm.net/forums/ev...icer-wing.html
Old Mar 23, 2009 | 03:24 PM
Mr. PSSsSt's Avatar
FCOTM Winner
i took a long knife and cut thru the adhesive on both side, which loosened up the wing.
Old Mar 23, 2009 | 03:38 PM
pcamara17's Avatar
yea i tried using the search and could not find anything then googled it still could not find anything so all I have to do is remove adhesive and then remove how many bolts??
Old Mar 23, 2009 | 03:39 PM
pcamara17's Avatar
another question is when I put the wing back do I have to apply some more adhesive on it then blot it back on?
Old Mar 23, 2009 | 03:41 PM
apagan01's Avatar
easy easy.
get a 10mm socket, take the bolts and nuts,,,, take some string nylon or fishing line, and use it to cut the double sticky tape that holds the wing to the trunk, this way you wont scratch nothing,
Old Mar 23, 2009 | 03:44 PM
SilverShadow03's Avatar
Yes, you should put adhesive back on...thin double sided tape cut to fit..its an added layer of protection from any paint scratches the wing might cause and help it stick to the trunk. I would highly suggest AGAINST using a long knife like someone else mentioned and instead use fishing line to separate the wing from the trunk...You will then want to use some Goo Gone to remove the remaining tape left behind after wing removal both on the wing and trunk.
pcamara17's Avatar
thank you for all your help
Old Mar 23, 2009 | 03:47 PM
pcamara17's Avatar
yea i did use fishing line to debagged my trunk
Old Mar 23, 2009 | 03:53 PM
sdfontanini's Avatar
I just tied a rope to my wing and the other end to a tree and gunned it. Took 2 seconds to take off.
Old Mar 23, 2009 | 03:54 PM
^ lol
Old Mar 23, 2009 | 03:56 PM
apagan01's Avatar
very good
Old Mar 23, 2009 | 04:13 PM
JJsEvo8's Avatar
The answer is "NO". The wing is on there for a reason..
Old Mar 23, 2009 | 04:19 PM
tryal's Avatar
you def want to re-apply the adhesive or you will get rust spots like mine has because it didnt have adhesive
