HELP! Steering wheel clicking
Old Mar 30, 2009 | 01:12 PM
jebus27's Avatar
Exclamation HELP! Steering wheel clicking
There is a click and a slight movement when i pull the steering wheel forward, and it also clicks and moves slightly forward when pushing it back in, has anyone else had this problem, and is there an easy fix, or should i take it into the dealer?
http://www.youtube.com/watch?v=fL6a6WLHnjw
Old Mar 30, 2009 | 10:26 PM
jebus27's Avatar
anyone???
Old Mar 31, 2009 | 12:00 AM
EvoJoeIX's Avatar
ummmm
dont pull or push on it???
your only suppossed to turn it
if it bothers you that much just take it to a dealer, it should be fixed under warranty
Old Mar 31, 2009 | 10:29 AM
JJsEvo8's Avatar
^^ Yea what he suggested, that doesnt sound right, my steering wheel doesnt pull in or out.
Old Mar 31, 2009 | 01:54 PM
jebus27's Avatar
well, if i take it to the dealership would they hassle me about the turbo timer, and try to blame it on that? should i take it off b4 i take it in?
Old Mar 31, 2009 | 04:57 PM
alianum777's Avatar
I dunno that's a weird noise, never had that before, try to see if the tilt/telescopic lever and locking mech is engaging properly. A little investigationg of your own might save you the troube of going to the dealer
Old Mar 31, 2009 | 05:56 PM
bsander's Avatar
I don't think the dealer would bother you about a turbo timer, at least they didn't bother me. Tell them it's healthy for the turbo
Old Mar 31, 2009 | 10:56 PM
jebus27's Avatar
thanks for the input guys
Old Mar 31, 2009 | 11:14 PM
EvoJoeIX's Avatar
the dealer CANNOT deny or void your warranty because you have mods on your car. dont listen to people on here that feed into that BS
UNLESS THE WARRANTIED PART'S PROBLEM IS CAUSED BY THE AFTERMARKET PART, YOUR FINE...
a turbo timer in no way would cause this problem
i myself would pull out the airbag and check to see if the nut on the steering wheel is tight. if it is, then id take it to the dealer cause its something in the steering shaft assembly(idk, what its called) that could be bad. but if you dont feel comfortable checking that, just go straight to the dealer
Old Apr 1, 2009 | 04:12 PM
1d10t's Avatar
sounds like the steering wheel nut is loose.
Pop the airbag out and see
Old Apr 1, 2009 | 06:30 PM
alianum777's Avatar
word of advise dont forget to disconnect the battery b4 you pull the airbag, just friendly advise
chrisff521
22
Mar 14, 2016 02:05 AM
TxFAkuma
Feb 9, 2016 03:07 PM
trevor
Jul 9, 2012 04:19 PM
Marroccowned
Jun 9, 2010 07:10 AM
AhmadHasib
Mar 28, 2007 05:11 PM
