View Poll Results: Do you watch World Chalenge?
All the time
71
35.68%
Whenever I catch it
89
44.72%
No, never
39
19.60%
Voters: 199. You may not vote on this poll
Evo to be possibly running in SpeedTV World Chalenge!
Old Oct 6, 2003 | 07:34 AM
Secret Chimp's Avatar
Re: Evo to be possibly running in SpeedTV World Chalenge!
Originally posted by Jurenic
EVO is a greate platform, and I think it has alot of potential. If all goes well, we should have the car ready for the start of next season at Sebring International Raceway. I will update you on our status.
Here comes the EVO!!
<< Dan >>>
This would absolutely rock. The Evo is a great platform and will be very competitive in that class....and SCCA will see to it that it is competitive. But they have to square away the dominance of the new Vipers that just popped up in the series a few races ago!
Got a free spot on your car to advertise for the largest Evo enthusiast site in the US?
SC~
Old Oct 6, 2003 | 08:23 AM
Ryanmcd2's Avatar
In Timeout
I have a friend who is running a T1 car in Atlanta, It's a NSX and to do something like that is over 250,000. I think GT runs about 125-150. But there are some cars like the Realtime NSX that is close to 400k.
Old Oct 6, 2003 | 10:27 AM
blurr's Avatar
Re: Re: Evo to be possibly running in SpeedTV World Chalenge!
Originally posted by Chris in HB
BTW, you might consider the Touring class for the very reasons mentioned in other posts.
No forced induction in Touring '04.
Old Oct 6, 2003 | 12:29 PM
drmosh's Avatar
Touring is also limited to 1.8 liters.
It would be great to see an EVO out there in the GT class, but most of the other cars are using bigger displacement with forced induction, including the RS6.
Old Oct 6, 2003 | 12:44 PM
DB8GSR's Avatar
I could've swore, I've seen a Subbie running on the Touring class. Not sure if it's a WRX but it doesn't really matter because it's always at the end of the pack.
Old Oct 6, 2003 | 01:41 PM
EVOtook's Avatar
Touring is limited to 2.8 not 1.8 liters. See rules below:
Classes: Speed Touring Cars must have a back seat in production form. They can be driven by two or four wheels. Engine displacement limit is 2.8 liters and they must be naturally aspirated (no turbo or super charging). GT cars may have forced induction. There is no limit to displacement and cars may be two-seaters.
Safety Modifications: Each car is equipped with a roll cage, safety harness, fuel cell, a driver's-side window net and an on-board Halon fire extinguishing system. The driver's seat must be replaced with an aftermarket racing-type seat. Drivers must be fitted with an approved head and neck restraint system.
Authorized Modifications: The front passenger seat and rear seats may be removed. Air-conditioning and radio also may be removed. All wiper blades, belts, hoses, filters, gaskets and electrical and ignition system components may be replaced with approved replacement parts. Fuel management is open.
Engine: Engines may be modified as per the Vehicle Technical Specifications (VTS) sheet for each make and model. Flywheel and clutch assembly are free, but ring gear must be of original diameter. The crankshaft and all parts of the reciprocating assembly must weigh within the manufacturer's weight tolerance.
Fuel: All cars must use a spec unleaded fuel from Sunoco.
Drive Train: Vent and breather lines may be added to the transmission and differential. Oil pumps and coolers may be used. Suspension: The suspension mounting points may be moved one inch and the wheelbase and track must remain as specified. Shock absorbers may be replaced, but must remain in the stock location. Any front or rear anti-roll bar may be used, provided it is bolted, not welded, to the vehicle.
Brakes: Alternative-material brake pads and shoes may be substituted for original equipment units. Both the Speed GT and Touring cars may use four-piston calipers, with Speed GT restricted to 14-inch maximum rotors and the Touring Car class restricted to a maximum 12-inch rotor. ABS is permitted only in Speed GT.
Exhaust System: All cars must use mufflers and must comply with the maximum 107dba limit.
Wheels: The standard wheels may be replaced with direct, bolt-on aftermarket wheels. Maximum diameters are generally 18" for GT cars and 17" for Touring Cars.
Bodywork: All Touring Cars may run spec rear wings and approved aftermarket body kits. GT car bodywork must be approved.
Tires: Speed Touring Car utilizes the Toyo Proxes T1-S ultra high-performance street tire. Tires may be shaved. In 2003, Speed GT Championship will utilize the Toyo Proxes RA-1 race compound DOT-approved tire.
Old Oct 6, 2003 | 02:35 PM
1krautburner's Avatar
One of the best outcomes of an Evo racing program will undoubtably be the development of reliable and readily available performance parts. As we all know, racing is by far the best development environment for aftermarket as well as factory parts. It will also be nice to see the Evo kicking butt on the Speed Channel !!!
Old Oct 6, 2003 | 08:30 PM
redphage's Avatar
Edited by SC....
I deleted your little flame.
Don't ruin an otherwise interesting thread. Take your childish rant to PM.
SC~
Old Oct 7, 2003 | 05:09 AM
sir lurks alot's Avatar
I can't wait! I'm sure you could get plenty of people on this board to help you in some way with this venture. There are lots of resources here. Good Luck!
Old Oct 7, 2003 | 10:08 AM
redphage's Avatar
Gosh, Im really sorry.
Good luck in the Tour Danny, can't wait to see you out there.
Old Oct 7, 2003 | 04:02 PM
masterevo's Avatar
Best wish from be too. I hope you going to make it. I would to see an EVO out there kicking those sorry asses. ahahha. By the way, what channel is all this races on? Speed? I hate NASCAR!!! IT is so boring to watch. And at what time is best to catch all of these actions on SPEED? THX
Old Oct 8, 2003 | 09:22 AM
djsanchez2's Avatar
any idea on what type of paint scheme u r going with. as soon as you make a decision and get started, it would be cool to see pics of a race prepped evo. i know the evo is a capable machine but i applaud you anyway that is one of the coolest things i have ever heard.
Old Oct 8, 2003 | 12:33 PM
MD@'s Avatar
MD@
EVOtook is right. The Subaru in TC is the 2.5RS of Irish Mike's Racing. No turbo, and no wins either.
Old Oct 8, 2003 | 10:42 PM
mhgsx's Avatar
Try contacting Archer Racing up in MN. They successfully campaigned Eagle Talons in GT class back in the days. Perhaps they could give some tips to help you out.
Old Oct 9, 2003 | 06:28 PM
evolutionist's Avatar
Go for it. I would love to see it run with the Audi's. It looks like the new viper is sorted out and the BMW team is running strong. Put the EVO on the track.
