Exhaust Wraps
Old Jul 3, 2009 | 06:54 AM
MMMR0820's Avatar
Exhaust Wraps
Has anyone done exhaust wraps on any of their Evo's? Do you reccomend it?
Old Jul 3, 2009 | 07:02 AM
chu's Avatar
chu
I have my entire downpipe and cat delete wrapped with the DEI stuff I bought from Pepboys. It works pretty well in keeping the temp from spreading. I did it mainly because the dp comes so close to the oil pan, and I want to control heat to transfer to the pan. Planning to wrap the back section by the diff too. Easiet way is to do it with the exhasut off the car.
Old Jul 3, 2009 | 07:13 AM
2LOFD3ATH's Avatar
Yeah, it's great to wrap the entire system if possible, it will actually make the car more efficient mpg wise and oboviously keep heat from spreading to other parts of the car.
Old Jul 3, 2009 | 07:29 AM
asininedervish's Avatar
What about a wrap would boost the mileage? I thought it was primarily a form of heat control?
Old Jul 3, 2009 | 08:13 AM
2LOFD3ATH's Avatar
Provides a more complete burn by keeping the exhaust temps as hot as possible all the way out. It is basically non noteworthy, however as with any car guy, any bit of anything is better.
Old Jul 3, 2009 | 08:19 AM
chu's Avatar
chu
I dont know about increasing mileage, but I have read that exhaust will move at a faster rate if the temp is hotter. I ran a dp only for 1 week, and my gas mileage was up dramatically, even with CELs thrown, not sure if it was due to flow rate, but like I said, it's wrapped.
Old Jul 3, 2009 | 09:43 AM
travail's Avatar
This is what I have on my down pipe Lava Wrap. Withstands 1200°F continuous and 2000°F intermittent
http://www.heatshieldproducts.com/lava_wrap.php
Old Jul 3, 2009 | 11:29 AM
MMMR0820's Avatar
Thanks for the info guys. Any pics?
Old Jul 3, 2009 | 11:42 AM
SLYDOGRACING's Avatar
What eric is saying is true!! We have found on our motorcycle dyno when a header is wrapped and engine under full load the egt's are higher plus the mixture is leaner by .1 or .2
Old Jul 3, 2009 | 01:48 PM
Epix_'s Avatar
Its definitely worth wrapping the o2 housing and down pipe. As stated above the whole concept is to keep the heat inside the exhaust piping which helps it flow faster through the system. We wrapped my friends megan downpipe because we suspected it to be the cause of a noise he was having at part throttle operation. Sure enough once it was wrapped it muffled the sound and now you don't hear it. So if you wrap the exhaust, expect it to be a little more quiet in car.
I've wrapped the exhaust on a few cars and as long as you do it correctly you can grab the ehxuast while the car has been running for a long time and not get burnt.
Also once its wrapped there is a high temp spray you need to coat the wrap with. This helps it cook onto the exhaust piping and seals it up nicely to keep all the heat in.
Old Jul 3, 2009 | 05:45 PM
2LOFD3ATH's Avatar
I can't remember the stuff I used when I wrapped my mx and sport bikes but it was at least 2500* since those glow red hot. I did have to re-jet/tune after it however. I'm going to wrap mine when I get my turbo manifold in and wrap everything back to the muffler, I hope don't drag it because at the muffler piping I have 3.5inch ground clearance and this **** unravels fast and makes a mess.
Old Jul 3, 2009 | 08:22 PM
JJsevol's Avatar
How many feet are you guys using from down pipe to end?
Old Jul 3, 2009 | 08:26 PM
TommiM's Avatar
Is ceramic coating a better option than the heat wrap?
Old Jul 3, 2009 | 10:46 PM
whiptheevo8's Avatar
Originally Posted by tommim
is ceramic coating a better option than the heat wrap?
+1
Old Jul 3, 2009 | 11:19 PM
NsinEvo8's Avatar
25' plus for dp.. i did the entire tbe and used 75' of black header wrap, 2" wide 1/8" thick.
