Is there a trick to wiring the defi D egt?
Old Jul 24, 2009 | 08:58 AM
rawburt's Avatar
I recently bought one used (the old amber display that was discontinued) off a member on here and cannot get any response from the probe to the gauge. I can get illumination and what not and I feel like I've tried every combo trying to wire the damn thing. There are 4 wires for power... Red, black, white, orange.
Now before I assume the the egt probe is bad and try to get my money back, is there any trick to wiring this thing? Looking to get this resolved this evening.
Old Jul 24, 2009 | 12:02 PM
Z_Lancer_Man's Avatar
Red = switched 12 volts (like from cig lighter, or radio) - gets 12 V when key is "On"
Black = Ground (try to attach it directly to the chassis)
White = Signal Wire (should come from the probe)
Orange = Illumination switched power (like when you turn your headlights on) - Most people just tie this one to the Red wire so it's always lit.
Hope that helps.
Old Jul 24, 2009 | 12:14 PM
rawburt's Avatar
that does help, thank you. The only thing is, the white wire does not come from the probe. the probe has its own connector that goes into the gauge. the power is separate.
Old Jul 24, 2009 | 12:17 PM
Ah... without doing a search on the specific wiring diagram for this gauge, I'd guess it's either a signal output (for data logging?) or a different color lighting perhaps? I know that the Prosport gauges allow you two different backlight colors (like Amber or White) depending on which wires you hook up.
Old Jul 25, 2009 | 10:18 AM
mitsuclipsegsx's Avatar
Why not just get a wb instead?
Old Jul 25, 2009 | 07:49 PM
EvoJoeIX's Avatar
because they serve complete different functions....
dont post if your not gonna help the guy out
op, are you saying the gauge lights up and everything but doesnt work? im haveing trouble understanding the problem
Old Jul 25, 2009 | 07:51 PM
EvoJoeIX's Avatar
prosport gauges are supposed to be white and then turn orange/red when you turn your headlights on... its not supposed to be a choice thing, but i guess you can wire it to your liking.
Defi gauges dont change colors, at least i know the high end gauges dont
Old Jul 29, 2009 | 05:28 PM
generalu's Avatar
Sounds like dead probe. Defi's are usually easy to install. Look to figure out what the white wire is for. Good luck.
But I agree, should've saved your money and when for a wb.
superlemonevo
10
Jan 20, 2010 08:42 AM
GTVEVO
Aug 26, 2009 07:59 AM
krayzeviet
Automotosports - Illinois
Nov 27, 2006 01:37 PM
Derek888
Oct 10, 2005 06:30 AM
Claudius
Feb 28, 2002 01:01 PM
