AEM UEGO Question
Old Aug 8, 2009 | 03:16 PM
stock_evoIX's Avatar
AEM UEGO Question
Just did a quick hookup of my AEM UEGO to make sure everything works.
With the car just running, there are just three dashes and no numbers which doesnt seem right. My friends with UEGO's the display fluctuates based on AFR..mine doesnt do that....At part throttle the AF is around 14.8, 15ish
I just did my FP Green, TP, DP as well today and the car is untuned, so i stay out of boost..what could the problem be?
Thanks in advance.
Old Aug 8, 2009 | 04:10 PM
RedEcotecSS's Avatar
hmm...
maybe the wideband needs to be tuned? theres a little thing on the back of it for that.. consult AEM first though..
also, you did put the o2 in the downpipe before the cat, right?
Old Aug 8, 2009 | 04:18 PM
N3VO's Avatar
yeah at idle you should still get readings. by partial throttle if thats daily driving then those readings are good. how old is the sensor and where did you mount it?
Old Aug 8, 2009 | 05:57 PM
everything is brand new outside the box
Old Aug 8, 2009 | 07:28 PM
Need4Spd's Avatar
Mine did this when I first installed it and then after driving around, etc., it worked fine. Go drive around and report back....
Old Aug 9, 2009 | 08:43 AM
McLaren F1 2003's Avatar
^^^same experience here
i thought it was broken at first, but after i started driving it worked
Old Aug 9, 2009 | 11:29 AM
EvoJoeIX's Avatar
did you mount the sensor at the proper location and proper angle?
you could have a bad sensor
Old Aug 12, 2009 | 01:16 AM
gregrego's Avatar
my uego did the same thing, and I drove the car around and it cleared up, and showed proper readings.
Old Aug 12, 2009 | 09:36 AM
Danner's Avatar
what does a 10 degree angle from horizontal do better than a putting it straight on top of the downpipe?
Old Aug 12, 2009 | 01:22 PM
05blue8's Avatar
Good question, mine was brand new and it worked right out of the box, no driving around needed...
kimma
Jan 30, 2012 04:19 PM
TomTomTuning
Oct 31, 2011 01:39 PM
cpunlamd
Jun 6, 2010 03:20 PM
Evolessfornow
Jul 6, 2009 11:11 PM
JDM-Spec.com
AEM EMS
12
Sep 16, 2004 02:00 PM
