wierd noise
Old Aug 8, 2009 | 06:31 PM
WRECKLESS96's Avatar
wierd noise
just bought a evo 9 rs. the car makes a light honking (even though it not the horn) sound when ever i have the air on. at idle it almost kills the motor and make s the honking sound when the rpms are up
any ideas
Old Aug 8, 2009 | 06:38 PM
MR_Lance's Avatar
think you could post up a sound clip?
Old Aug 9, 2009 | 05:02 PM
Prodigy's Avatar
Alarm maybe? short?
Old Aug 9, 2009 | 06:16 PM
BoostIsMyDrug's Avatar
It only makes said honking sound while the RPM's are up? Have you tried narrowing down where the sound is coming from? Have a friend hold the RPM's up while you snoop around... As was said, a sound clip would help but you can narrow it down by letting us know where about this sound is coming from.
Old Aug 9, 2009 | 11:47 PM
Prodigy's Avatar
There is not many things in the car that could make the sound maybe your horn has short..
Old Aug 10, 2009 | 01:42 AM
no its not the horn. it sounds like a rubbing noise but its not a squealling. so my question is what do the air and the engine have that work together that move. remeber it onlt happens when the air is on
Old Aug 10, 2009 | 01:49 AM
Pal215's Avatar
i don't the engine has anything to do with the air being on, but when you switch your ac switch on, the engine does have to run the ac compressor....
Old Aug 10, 2009 | 02:51 AM
mini_evo's Avatar
what it sounds like to me is either your A/C compressor is taking a poop (can't say **** on this forum)... or the vent fan is rubbing the housing when it blows the air inside the car.
But if it it gets louder when the RPM's are raised..... then I am willing to bet your compressor bearings are going bad... if not already bad.
Old Aug 10, 2009 | 11:08 AM
if it was the ac compressor wouldn't do it when ever the engine was running. if it was the blower an rubbin on the housing why would it almost kill my engine
Old Aug 10, 2009 | 02:01 PM
just had m car checked out. something is wrong with the ac system. he thinks it is some kind of blockage might be a bent line. probably when i they put in the intercooler
Old Aug 10, 2009 | 10:24 PM
nebevo's Avatar
Could be the ac compressor CLUTCH, when it trys to engage it cant fully engage so its slipping making the honk sound idk just a shot check the bearings also
Old Aug 10, 2009 | 10:40 PM
RoadSpike's Avatar
If its a bearing failure on the accessory belt say like... water pump, AC, power steering, etc. It would make a horrible brake like howling noises and then cause massive power loss including idle going way down. If by chance the bearing problem was intermittent its possible it would only occur at higher rpm especially things with a journal bearing.
As a note it is really hard to say based on your comments of a honking noise but the noises i envision are best diagnosed with a mechanics stethoscope to determine their point of origin.
Good luck hope its a simple fix.
shupadupa
18
Dec 14, 2015 09:48 AM
bboy_RES
Apr 3, 2009 11:33 PM
UCLAevoIX
Aug 2, 2008 07:05 AM
bu.stefan
Jul 27, 2004 01:22 PM
