Walboro installed, won't turn over..
Old Aug 14, 2009 | 02:44 PM
CoMoEvo's Avatar
okay so i feel like an idiot, unless this pump is bad..
i've done fuel pumps a few times and always with success.
i installed a new walboro 255 lph in my evo, got everything plugged back in, crank the car and it tries to turn over just barely for about a second or two before nothing and just the starter is going.
if you try and crank it then stop and almost immediately try cranking it again, the car won't even turn at all; however, if i pause briefly, the car will try and turn over.
when i turn the key to ignition on i do not hear the pump firing on, it's only while cranking to i hear the walboro doing its thing.
any suggestions while i go ahead and pull everything out?
just out of curiosity what is the blue wire that is wired into the harness that plugs into the pump do?
thanks,
j.
Old Aug 14, 2009 | 03:04 PM
CoMoEvo's Avatar
okay pulled it out, saw that the walboro cap was off center.. i noticed when disconnecting the lines they were dry. problem: pump wasn't able to pump fuel to the lines.
solution: toss the crappy walboro cap, and reuse oem
car fired right up and runs fine now..
glad that was nice and easy; however, i lost one of the 6mm bolts that holds the black ring over the top hat down.
Old Aug 14, 2009 | 03:15 PM
J.Js evo9mr's Avatar
^^ congrats on the install my friend!
Old Aug 14, 2009 | 11:23 PM
RockmanX's Avatar
i could have told you that lol have a whole guide to walbro install and many many others on my website but yea i had the same problem but mine was black oring was not parrell in houseing so pump was not building fuel pressure. took me 6 hours to figure it out on my own as i do all my own installs and NO evo shops even close to me.
Old Aug 14, 2009 | 11:34 PM
Evokid8's Avatar
i had the exact same problem! but my car misfired badly so i messed with the coilpacks (waste of time) to figures out it was that cap thingy under the rubber grommet i forgot to take from the oem pump
Old Aug 15, 2009 | 02:11 PM
CoMoEvo's Avatar
yup gotta reuse the oem piece.. if will allow the pump to fit nice and secure in the fuel pump assembly.. the walboro stuff they send to replace it JUNK.
Old Aug 15, 2009 | 03:04 PM
RockmanX's Avatar
pretty much junk left over parts for the win buying the evo install kit was a waste of 2 extra dollers i only used the small plastic locking clip
Old Aug 15, 2009 | 04:47 PM
CoMoEvo's Avatar
^i'd agree, i liked using the new fuel filter though that came with the kit
Old Aug 15, 2009 | 10:32 PM
firstaltevox's Avatar
This is where the importance of oem parts eh lol but congrats on th einstall
xceler8rob
34
Jul 17, 2016 12:57 PM
Viet-Speed
Apr 23, 2013 03:57 AM
Notch
12
Aug 12, 2011 12:05 PM
kansaslancer02
Lancer Troubleshooting
Apr 10, 2008 03:55 PM
Racer1
Feb 28, 2005 08:32 PM
