Bad tank of gas?
Old Aug 19, 2009 | 08:50 AM
zignus's Avatar
Bad tank of gas?
So I was on my way home from work Monday night (1100 mile drive) and I fill up for the first time in mississippi. The car ran fine untill next time I filled it up. When I accelerated going down the on ramp the car just fell flat on its face about 4k rpm. It felt like i just turned the ignition off. So I shift into 3rd and it revs fine till 4kish and it goes flat again. Going down the interstate at 70mph it ran fine and it pulled fine in 4th from 40 to 70.
Next fill up same thing happened when I tried again on the on ramp. But after the next fill up it ran fine and pulled hard in 2nd to 7k rpm. Think it was just bad gas and the ecu pulled timing or could it be a fuel pump/filter issue?
Old Aug 19, 2009 | 08:55 AM
MEVOLV3's Avatar
Throw any codes?
Old Aug 19, 2009 | 08:57 AM
boostedtres's Avatar
did u get any check engine lights or cels?
Old Aug 19, 2009 | 09:02 AM
zignus's Avatar
No check engine light at all.
Old Aug 19, 2009 | 01:33 PM
zignus's Avatar
Any ideas?
Old Aug 19, 2009 | 07:11 PM
djslik408's Avatar
how about try using fuel injector cleaner? You can always drain your tank and start totally empty with fresh good gas.
Old Aug 19, 2009 | 07:16 PM
evoIXcencal83's Avatar
Check you IC pipes, one probably popped off.
Old Aug 20, 2009 | 02:16 AM
huevosrancheros's Avatar
Originally Posted by thientran
How do u drain the tank of gas?
you remove the fuel pump, unbolt the tank and voila
Old Aug 20, 2009 | 01:16 PM
Noogie's Avatar
Thats what happened to me, check your clamps make sure they are down tight with no leaks or anything
Old Aug 20, 2009 | 02:01 PM
zignus's Avatar
Ill take a look at the pipes. But its running fine now so I dont think it was that.
Old Aug 21, 2009 | 07:26 AM
EvolNinja's Avatar
IF the IC pipe pop off, he wouldn't be able to go 40 to 70mph... Not even 30mph
awdordie
17
Feb 26, 2017 09:16 PM
khoyer
Dec 6, 2016 10:00 AM
05EVORonmc
Jan 27, 2014 02:52 PM
EvocentriK
14
Jun 19, 2013 08:05 PM
Xterminater
11
Nov 20, 2010 07:45 AM
