Zeitronix Wideband/Boost Question
Old Sep 10, 2009 | 06:34 PM
LANCEREvo9MR's Avatar
why on this wideband on boost it doesnt tell me full boost till i hit the limiter ive seen analog boost gauges that as soon as youre spooling they tell u ure full boost?
Old Sep 10, 2009 | 06:39 PM
Evoryder's Avatar
Like the Greddy Profec B? Or Defi?
Old Sep 10, 2009 | 06:48 PM
Defi
Old Sep 10, 2009 | 06:51 PM
Evoryder's Avatar
would be nice huh? I was also spoiled from a similar unit, my profec b which show'd peak boost.
I am very satisfied with the consistency of the unit.
Old Sep 10, 2009 | 06:54 PM
i am 2 i love my zeitronix wideband/boost gauge but its annoying i gotta watch it at redline to see the boost it does have a button to show peak but i dont know, would be nice to see peak as soon as u spool
Old Sep 11, 2009 | 06:29 PM
Dr.Sound's Avatar
are u curious to see your spike, or what your boost is holding at?
i think the holding of boost is more important than a millisecond spike.
Old Sep 11, 2009 | 09:28 PM
falcontx's Avatar
Are you using the optional LCD? If so, that's why. It only updates 3 times per second, and like all LCDs, it also takes time for the crystals to be adjusted, so the data you're seeing is probably anywhere from 100 to 300ms old. An analog gauge, on the other hand, has practically no delay at all.
Old Sep 11, 2009 | 09:32 PM
Gordian79's Avatar
Datalogging is the best way to Know your boost at x rpm at x afr.stock ecu and standalones can do this.
Old Sep 11, 2009 | 10:39 PM
RoadSpike's Avatar
All the gauges have a peak whatever function be it egt, boost, or whatever.
To display the peak boost do the following.
Round digital AEM like gauge:
hold the button on the lower right hand corner like you are going to switch views for a moment it will switch over to pAFR which is the lowest spike in AFR, adjustable i think in the software. Pressing the button at this time will show you peak boost, eft, etc as it switches views. To get back just hold it down again, warning doing this will clear your peak boost out of memory as well so you can't go immediately back.
Its under the 2 button functionality part
http://www.zeitronix.com/Products/ZR...structions.pdf
Square LED gauge:
Same deal but i don't remember holding it down i think just pressing the button did the switch since it displays ALL at once. The button on this gauge was on the lower left hand side IIRC and was on the side not the face like the round gauge.
DailyRally
Feb 25, 2017 05:00 PM
TxFAkuma
May 11, 2016 06:26 AM
Femi
AEM EMS
23
Apr 5, 2016 11:38 AM
blackonblackevo
Jun 6, 2007 11:55 AM
Inprogress
Oct 22, 2006 10:10 PM
