Wideband Bung
Old Sep 12, 2009 | 02:08 PM
thedru13's Avatar
Wideband Bung
Where should I have the Bung Welded on my Downpipe for my Wideband bung? I have a Works Downpipe. For my Evo IX MR Any suggestions?
Old Sep 12, 2009 | 02:30 PM
Chemwarrior's Avatar
At least 24 inches away from the turbo and forward of the catalytic converter. Ensure it's around the 3 o'clock position.
Old Sep 13, 2009 | 10:48 AM
thedru13's Avatar
Thanks. When you say 3 o'clock position is that tilted towards the passenger or driver side.
Old Sep 13, 2009 | 12:21 PM
mini_evo's Avatar
The wideband should have had instructions with it IF you bought it new. if not... It states 36" from your Turbo. And Yes, 3 o'clock is the passenger's side of the downpipe.
Old Sep 13, 2009 | 12:27 PM
thedru13's Avatar
Yah didn't buy it new. Its an AEM Eugo. I wasn't sure if the MR was any different. Or if the 8 placement was different from the 9.
Old Sep 13, 2009 | 03:53 PM
letMeIn's Avatar
you can do it at 12 as well. There is enough space
Old Sep 13, 2009 | 03:58 PM
McLaren F1 2003's Avatar
12 oclock worked out better for me
Old Sep 13, 2009 | 05:06 PM
Kracka's Avatar
Just put it in your stock rear o2 sensor bung (assuming you're not running a cat).
Old Sep 13, 2009 | 05:45 PM
thedru13's Avatar
I am running a cat..
Old Sep 13, 2009 | 06:12 PM
AznEvoIX's Avatar
Just put it before the cat and you should be fine. Or else you're going to get incorrect readings.
Old Sep 13, 2009 | 06:52 PM
raginghadron's Avatar
What's this on page 2? An aptly named thread! https://www.evolutionm.net/forums/ev...-question.html
I've seen manufacturers that say NOT to weld it at the 3-o'clock position because of the risk of condensation building on the sniffer. It's recommended to weld it no less than 10 degrees and no greater than 75 degrees to the horizontal. I have a diagram in the thread linked above.
ThaoDao
Jul 7, 2014 02:32 PM
Blue91lx
Sep 29, 2011 12:02 AM
Gibby860
11
Sep 16, 2009 05:15 PM
LakerRaider
Jan 17, 2009 11:18 AM
BlackonBlack2
10
Sep 28, 2008 09:47 AM
