EVO IX MR 136k miles, tried to take me out...
Old Sep 20, 2009 | 09:50 AM
Smike's Avatar
There is carbon build up in the throttle body butterfly. Take off the throttle body, take off the TPS sensor, get TB cleaner, clean off the TB.
Old Sep 20, 2009 | 07:31 PM
sneezinevo's Avatar
sounds scary man. luckily its never happened to me. **knock on wood**
Old Sep 20, 2009 | 08:03 PM
MitsuJDM's Avatar
Yikes. Did you by any chance relocate the cable to hide it? I did this on my old Evo and the throttle was really stiff so I put it back. With my new Evo I thought I'd give it another try and was getting crazy throttle hang between shifts. And yes, there weren't any kinks.
Other than that, that's scary. My first reaction would be "AHHHHHHHHH!!!!". Then my second reaction would be clutch in, key off, and neutral to the size of the road. Damn.
Old Sep 20, 2009 | 09:23 PM
MTRJunior's Avatar
Originally Posted by ODUB
he could have just pushed in the clutch. might have blown the motor, but that's safer than running redlights. also, the turbo timer shouldn't have been able to activate without the ebrake being pulled so that car wasn't wired right to begin with.
lol I think I'd rather run some red lights than blow my motor =P
Old Sep 21, 2009 | 10:55 AM
Rxracer's Avatar
This has happened to me, but my floor mat caught my pedal.. scary feeling for sure..
Old Sep 22, 2009 | 11:49 AM
92gsxbaltimore's Avatar
Happened in one of my 1gs a while back. I was goosing it coming around a on-ramp on the highway, and it stuck open. kicked the car sideways, but i killed the ignition and recovered. It was wore out throttle body shaft seals. I put some new ones in with some silicone grease and it was smooth again. Also, when they wear, you leak boost.
Old Sep 22, 2009 | 01:34 PM
LiLRJ55's Avatar
Man that's scary
Old Sep 22, 2009 | 09:17 PM
ODUB's Avatar
the throttle body was just pulled, cleaned, and serviced like 15k miles ago. it used to stick closed a little bit when the car was cold. that went away completely. the throttle body is clean.
Old Sep 23, 2009 | 08:55 AM
EvolNinja's Avatar
I did the throttle cable relocation. Hope that will not happen to me. Knock on wood. Hope you get it fixed.
xBoostx
Oct 7, 2016 01:47 AM
Babs
Jul 11, 2013 06:42 PM
gieri002
Dec 29, 2010 12:44 PM
Slimdatwelve209
Jul 4, 2008 10:49 AM
VTEC Killer
AEM EMS
Jan 28, 2008 10:11 AM
