Its cold as **** and the heat dont work?
Old Jan 24, 2010 | 07:28 PM
Stevo IX's Avatar
Damn it sux to be in the cold with no heater in your car.
Old Jan 24, 2010 | 09:05 PM
blownevo's Avatar
Originally Posted by eXtreme-Speed
have you noticed any puddles under the car? Maybe your thermostat or heater core went.
I agee.
Old Jan 24, 2010 | 09:42 PM
huevosrancheros's Avatar
Originally Posted by recompile
thermostat stuck
If the car takes a long long time to heat then then its the thermostat that is stuck in the open position.
When my girl's geo metroid's heat went out, it was the damn heat plug(it looks like the inside of a light bulb) it goes directly into the blower.
Old Jan 25, 2010 | 08:22 AM
barneyb's Avatar
thermostat stuck
I owned a DSM and one winter day no heat. I figured the thermostat was stuck open and obtained a new thermostat. When I pulled the installed thermostat it was shut. Puzzled by this, I put both thermostats in a pan of water and heated them on a stove. The thermostat that came from the car opened first. It was opening before the coolant got hot enough to provide heat for the cabin. So, this is another mode of failure.
Old Jan 25, 2010 | 08:29 AM
gsrboi80's Avatar
Also make sure you heater knob isn't the issue. The heater controls were an issue on the early EVO's Mitsu put out an upgraded blend door kit to fix the issue
Old Jan 25, 2010 | 11:52 AM
barneyb's Avatar
Originally Posted by IllFactor
In need of heater core and vents asap. Does any one have a heater core?
It is way too much work installing a heater core to consider anything but new.
lghtngyello03
May 1, 2020 01:15 AM
Hitmachine101
Jan 16, 2015 07:52 PM
D1Fuse
21
Jul 1, 2013 10:59 PM
ChipperEvo
18
Mar 25, 2013 12:07 PM
neurotic ramble
Lancer Troubleshooting
13
May 2, 2011 08:38 AM
