Easy way to raise/lower headlights
Old Oct 22, 2003 | 10:26 AM
XLR8R's Avatar
Thumbs up Easy way to raise/lower headlights
After struggling for 20 minutes with a flathead screwdriver, my friend and I gave up and started trying random tools on the little gears and the nut in the center. 5 minutes later, we found that a 10mm socket attached to a standard length handle fits perfectly over the nut. Another 5 minutes and both headlights are now at the perfect level. The drive home on 280 was sooooooooooo nice...I can actually see down the road
Hope this helps others trying to aim their headlights higher.
Old Oct 22, 2003 | 10:34 AM
93civEJ1's Avatar
ok...so all we need is a 10mm socket and we turn what and do what??? we need more instructions.
Old Oct 22, 2003 | 11:23 AM
cky3396's Avatar
yeah, please do elaborate
Old Oct 22, 2003 | 11:29 AM
Lightsped's Avatar
Photos could be helpful. Thanks
Old Oct 22, 2003 | 11:34 AM
Fireball's Avatar
Just use a phillips screwdriver. That's what the gears are made for.
Old Oct 22, 2003 | 11:43 AM
Corey's Avatar
I love the HID's on my Evo, but I have a hills on my road going to my house. as I come down the hills it seems the HID's point straight to the ground and I can't see hardly anything unless I hit my high beams on.
I guess I'm gonna have to look around the headlight assembly and see what your talking about because I have no idea. Thanks for the helpful hints though.
93civEJ1's Avatar
yeah i have mine at the highest setting and they are still low, I am just to lazy to fooll with them.
Old Oct 22, 2003 | 11:50 AM
evo_dadi's Avatar
keep it on 0 thats the default setting putting it on 4 makes it point down more towards the ground.
Fireball's Avatar
There's a little hole, with some gear looking things in them. The hole is big enough for a phillips screwdriver. There are a couple pictures on here, but I'm too lazy to search for them right now.
You put a screwdriver in there, and slowly crank. Takes a number of turns, but that's how you adjust the headlight levels.
Old Oct 22, 2003 | 12:18 PM
jotan82's Avatar
wow, gotta try this when i get home
Old Oct 22, 2003 | 12:20 PM
93civEJ1's Avatar
yeah i know 0 is the highest, thats where its been forever...Ive known this since i have had the car...thanks anyway though.
Old Oct 22, 2003 | 01:09 PM
Fireball's Avatar
What I did, and it really helped....
Park your car near a wall or something.
Turn on your headlights, so you can see where the beam is. It's a pretty easy way to tell what you're doing, because the beam ends so abruptly.
Mark where your lights are at the 0 setting. (Highest)
Turn your lights down to 2 (middle)
Use the adjustment screws to move the lights back up to where it was at 0.
Now you have 2 more levels to go, higher than 0.
I find that setting 1 is perfect... you get flashed for brights every once in a while.
Level 0 is extreme now. You'll get flashed for brights almost all the time.
Old Oct 22, 2003 | 01:22 PM
Fireball's Avatar
Picture of what the gears look like:
webguy330i's Avatar
Fireball, my plan precisely, good call.
Old Oct 22, 2003 | 01:26 PM
GokuSSj4's Avatar
thanks for the info , does this required to do it on just in one (automatic adjusting the other ) or individually ???i will have to try that ....
