Project: Rebuilding the Salvage Evo
Well its been a while since I have updated this thread, but I haven't forgotten about the car. I have been pretty busy working on other projects in the shop. I have really been waiting for some small parts to come in for the car. Like oil and cooling lines for the turbo and a MAF sensor.
I was able to spend some time working on the car last night and got it running. It feels good to hear the car finally run after owning it for nearly a month!
There will be more updates to come as I have a nice long break coming up for Christmas!
awesome man! i plan on picking up a salvaged evo or a shell and rebuilding it in the next couple years. just need to get out of this condo so i have a real garage to work in.
keep up the good work!
Well if you need any help locating one let me know! I buy from the insurance auctions every week.
I picked the car up pretty cheap but I bought it not knowing if it ran. It turned out to be a really nice car though.
Little update. The car is back from the frame shop. After getting the impact bar, I noticed the passenger frame horn was still a little tweaked so I had that taken care of. The MAF sensor also showed up. Boy the car idles a lot better with that! haha
The lines on the turbo & wastegate are just vacuum line that go to the boost controller. You can pick it up at any parts store. Make sure you zip tie it on though. The nipple on the intake takes a little bit larger hose & goes to the valve cover for crank case vent. That also could be picked up at any parts store.
actually after looking at your engine pics again I see that the crank case vente tube is still on the valve cover. It's the one on the drivers side front corner of the valve cover. Looks like it's either just tucked out of the way or it's routed to a catch can. I'd guess its just tucked out of the way since it looks like the stock line still. Just route it to the nipple on the intake pipe.
I see that there are two nipples under my air filter mounted to the frame with a harness plugged in it. Any chance this is the place where I should run the lines.
