Evo 8 upgrades
Old Nov 24, 2009 | 08:31 PM
Spac3clown's Avatar
Evo 8 upgrades
I have a few questions on near future upgrades for my car. My car is now approaching 88k miles.
Current mods are listed below in the signature.
I need advice on what I should install next. Would I benefit from a Walbro 255hp fuel pump and a new FMIC?
Since I already have Megan headers and Megan tbe would it be safe to say there is already a Megan 3" down pipe already installed? If not I was looking at installing one. I am also looking at adding a Megan o2 housing if that will help also.
I run 93 octane as well.
Old Nov 24, 2009 | 08:44 PM
EvoRob22's Avatar
Buschur Upper I/C and Buschur FMIC would be my next upgrade. You will also see gains out of the 02 housing. I would assume the Megan would be 3 Inch.
After the Intercooler, I would do the fuel pump and larger injectors if you decide. Then cams.
Old Nov 24, 2009 | 08:46 PM
LOVEBOOOST's Avatar
With ur mods, my next upgrade would most likely be walbro 255 fuel pump... then go with the fmic
Old Nov 24, 2009 | 09:14 PM
4RETECH's Avatar
Fuel pump, easy and cheaper
Old Nov 25, 2009 | 06:40 AM
garcias2k's Avatar
As far as the downpipe goes, it's easy to see if you have the stock or aftermarket one. So I'd plan on getting those done next, then intercooler pipes with intercooler. Fuel pump, injectors, cams, then the list goes on. A new tune as well.
Old Nov 25, 2009 | 06:47 AM
erald01's Avatar
255 walbro, down pipe if you still have the stock one, boost controller if you dont have one, cams, intercooler.
Old Nov 25, 2009 | 07:07 AM
Wickedwhite8's Avatar
I know everyone is against ebay FMIC, I have one and I have made good power. Unless you are shooting for really high HP I would think the ebay XS power FMIC would be Ideal. For sure go with a walbro 255 pump. Just my .02
Old Nov 25, 2009 | 08:21 AM
aschold's Avatar
I've actually seen tests, I believe it was done by TTP but don't quote me on it, where that particular FMIC makes less power than OEM. It's highly inefficient. Bigger does not always mean better.
Old Nov 25, 2009 | 12:43 PM
ghammer2's Avatar
bigger intercooler lets you run more boost, more boost means more power, more power means more fuel... so I would try to install both if you could :x
Old Nov 25, 2009 | 02:21 PM
JJsEvo8's Avatar
Here is what i would do for best gains: Walbro 255 -> Injectors -> BOV -> ARP Headstuds -> E85 -> Tune. Can't beat that combo, will see 80-90 whp vs 20-30 with the IC/piping, and will cost less!
EvoVIII_03
Nov 10, 2011 01:20 PM
murderedevo256
12
Mar 19, 2010 06:49 PM
tsitalon1
Jan 3, 2010 11:26 AM
etuhs
30
Oct 25, 2009 02:44 PM
Apex Buddy
10
Sep 20, 2005 03:04 PM
