Need help with evo 8
Old Nov 28, 2009 | 07:46 AM
shaz340's Avatar
hi
i need help wit a few things and help would be really appreciated
the folllowing stuff are the things i need help with:
1)the first thing is the engine.it looks very dirty as seen in the picture (http://s1005.photobucket.com/albums/...t=Image008.jpg)and is there any way i can make it clean and bright again.
2)the second thing is the brembo brakes.as you can see in the pictures (http://s1005.photobucket.com/albums/...t=DSC05523.jpg)they have some white powder thing and can that be cleaned.
3)lastly the evo interior is beutifull but the downside is the chairs.is there a way i can get alacantra but on in the middle covering the blue colur so they look better.this is the picture for the seat(http://s1005.photobucket.com/albums/...t=Image004.jpg)
4)lastly the ehaust on the evo 8 can it be put bent and hih on the stcok bumper.image for exhaust place(http://s1005.photobucket.com/albums/...t=DSC05524.jpg)
help would be appreciated
many thanks
shaz
Old Nov 28, 2009 | 07:55 AM
Evo1001's Avatar
The brakes cannot be cleaned. The problem is in the clear coat. You can repaint them if you want.
Old Nov 28, 2009 | 08:16 AM
shaz340's Avatar
ok
Old Nov 28, 2009 | 09:22 AM
shaz340's Avatar
what about the other problems anyone
Old Nov 29, 2009 | 02:55 PM
evo8nfs's Avatar
with cleaning you engine compartment i would start with simply soap and water and see where you at. If you looking to use a degreaser.. simple green works great and it safe.... Your calipers are oxidized not too much you can do except re-paint. As far as your seats sell them and buy something else?? Im not really sure what your question is as far as your exhuast explain maybe?? hope this helps..
Old Nov 29, 2009 | 03:06 PM
IraqiVet's Avatar
The clear coat on the Calipers is a well-known issue for Mitsubishi (even though Mitsubishi denies problems with clear coat). You *could* have them refinished, and they'll look new.
Engine cleaning: some detail shops can clean it for you professionaly, but depends on if you're willing to spend the cash. As for me, Car-washing soap works OK but you're not going to get the 'sparkly-spazzle' effect. However, it will help get the dirt/grime off.
Old Nov 29, 2009 | 04:17 PM
JohnDoe1984's Avatar
Your engine bay looks like most of the problem is a little dust and dirt. It should come off with a little simple green and rags/spounges.
Your evo probably doesn't need this serious treatment but, common practice on sprucing up old car engine bays where I grew up was:
Take 2 cans of gunk engine bright.
http://www.gunk.com/item_details.asp
Before you start: Turn up the temp on your home hot water tank and hook a garden hose with a sprayer up to the drain fitting at the bottom.
Park the car in an appropriate area with drainage. Soak the whole engine bay, firewall, underside of hood with the gunk. Let it sit for a good 10 min or so.
Turn on the steaming hot water and rinse everything down good till the water runs off clean. The hot water besides cleaning and dissolving grease better also dries faster than cold garden hose water.
I've seen this same method work some miracles. It's made some scummy old engine bays look like new with little work.
Old Nov 29, 2009 | 05:50 PM
Berts24's Avatar
my dad took his car to a detailing place and they steamed clean it and it came out amazing!!! Most car detailing places will do it but I'm sure it's not that cheap. Clear coating the brakes have been covered here plenty of times and can be found by searching. The seat thing not really sure what you're asking and as for the exhaust I would take a look at the rubber hangers, maybe one is worn out
Old Nov 30, 2009 | 01:06 AM
shaz340's Avatar
ok thank you al for replying
Old Nov 30, 2009 | 05:19 AM
johnwood's Avatar
Just go to service center and you find all your solutions under one roof. why you waste time.
Old Nov 30, 2009 | 11:11 AM
Chris1091's Avatar
1. Get some Simple Green and rags..
2. Get them recoated/repainted/refinished.
3. Call your local auto upholstery store.
4. Have a local muffler shop look at it.
