Rattleling when letting off gas
Old Nov 30, 2009 | 05:44 AM
Evojj25's Avatar
Exclamation Rattleling when letting off gas
Ive been noticing a rattleling sound when you depress the gas on the higher gears, typically in 5th, i can hear it in the other gears but 5th seems to be the most present. Like if you were going 50mph and you let go of the gas and decel, you can hear it. can anyone tell me what is that please?
Old Nov 30, 2009 | 06:12 AM
4Trouble's Avatar
It could be loose clutch bolts
Old Nov 30, 2009 | 06:25 AM
jchild420's Avatar
does it happen all the time? I get a rattling sound in low gears when cold. it goes away after the engine warms. may be it could be a lose exhaust manifold bolt
Old Nov 30, 2009 | 06:40 AM
e\/olution's Avatar
I get some rattles too I think mine may be down pipe related
Old Nov 30, 2009 | 06:41 AM
BlueEvo61106's Avatar
It could be your exhaust. I used to get that as well with my exhaust when it was cold!
Old Nov 30, 2009 | 04:19 PM
Berts24's Avatar
sounds like loose heat shields on the down pipe
Old Nov 30, 2009 | 04:29 PM
alicea8541's Avatar
Or tranny, happened to me in August. If you still have a cat, it could be the shield rattling.
Old Nov 30, 2009 | 05:40 PM
Evojj25's Avatar
yes it happens every time i'm in 5th gear
Old Nov 30, 2009 | 05:41 PM
Evojj25's Avatar
yes, i still have a cat on it
Old Nov 30, 2009 | 05:43 PM
AF-Evo8's Avatar
what clutch do you have?
Old Nov 30, 2009 | 09:24 PM
Evojj25's Avatar
i think a stage 2 or 3 clutch, the person that had it before me had changed the clutch, but the evo was at an auction, but i know that the clutch is not stock.
Old Nov 30, 2009 | 09:33 PM
TSiAWD666's Avatar
Check for loose heat shields. The stock exhaust uses a pretty ****ty design of heat shielding plates held in place by band clamps. Well, the ****ty design really is the material chosen for the heat shielding as it rusts through pretty easily. The area of the shielding that slides under the band clamps can rust apart and allow the heat shielding to rattle around.
Old Nov 30, 2009 | 10:03 PM
Evojj25's Avatar
alright then. thank you everyone for helping me out about this problem, now i can tell my mechanic what the problem might be. thank you
Icegod87
Sep 24, 2014 04:48 PM
fromWRXtoEVO
Apr 21, 2014 06:57 PM
S2K2EVO
Jan 25, 2012 09:34 AM
enpe
Jan 23, 2011 12:39 PM
NavyEvoChief
Aug 7, 2009 08:31 PM
