CEL Po170. Help
Old Dec 8, 2009 | 09:11 AM
Yakshii's Avatar
CEL Po170. Help
Im going crazy trying to figure this out. Ive searched all over this forum with no results. Please someone try to chime in and help. The scanner reads a po170 (Fuel Trim Malfunction Bank 1). Is this an 02 sensor???
Because of this CEL it seems my Gas MPH has dropped significantly
Car: 2001 Evo 7
Mileage:8,000
Mods: catback,Cone filer, BOV (came with car), everything else. stock.
my gas is killing me and im tired of seeing the light.
Thanks in advance
-kemal
Old Dec 8, 2009 | 10:09 AM
SCREAM8's Avatar
what bov? that could trigger this cel as well as some crappy gas mileage.
Old Dec 8, 2009 | 10:17 AM
Yakshii's Avatar
The ****ty SSQ HKS
Old Dec 8, 2009 | 10:26 AM
SCREAM8's Avatar
Originally Posted by Yakshii
The ****ty SSQ HKS
find a DV, stock 9 or aftermarket like forge or synapse asap.
Old Dec 8, 2009 | 10:27 AM
Yakshii's Avatar
i doubt the BOV is causing the CEL though. the scanner reads Bank 1. so it cant be that. i thought it was at first due to the car running rich for a second between shifts
Old Dec 8, 2009 | 10:28 AM
TeStUdO's Avatar
Your gas mileage has dropped because your O2 sensor is bad and has your fuel trims pegged rich. It has nothing to do with your BOV.
Old Dec 8, 2009 | 10:30 AM
SCREAM8's Avatar
i vented my stock dv because the hose was cracked and got the same exact code.
regardless, he needs a recirculated either way.
Old Dec 8, 2009 | 01:15 PM
SmurfZilla's Avatar
Check all your IC piping. I was throwing that code and it ended up my IC was starting to get loose at the bottom where it connects to the throttle body (It looked visually fine but I started hearing more noise then normal when boost started to build).
Old Dec 8, 2009 | 02:38 PM
gsrboi80's Avatar
Threw this code when J pipe gasket was screwed on my old modded IX turbo. A simple boost leak test found it right away. New gasket from mitsu and I was good to go
Boost leak test the car man
Old Dec 9, 2009 | 08:39 PM
Yakshii's Avatar
thanks people.
much appreciated
yellowman
Mar 1, 2013 09:17 AM
chewyobaca
Dec 2, 2011 08:34 PM
evil6819
Mar 3, 2011 05:43 AM
trscOZo3
Lancer Troubleshooting
Jun 29, 2010 11:25 AM
