PO243 code ???? Anyone???
Old Apr 23, 2005 | 11:08 AM
yellowman's Avatar
I have a check engine light on and went to Autozone to pull the codes. Got 2.
A PO243 and a PO325.
I know that the PO325 is the knock sensor and may be due to faulty wiring for my SAFCII.
But what about the PO243? I looked on other sites for other cars and it sounds like a wastegate sensor or something...hmm..
Any help???
Old Apr 23, 2005 | 12:39 PM
bigjhoney's Avatar
What were you going when the 243 code came on? What kind of boost was it showing when the code came on?
Old Apr 23, 2005 | 02:22 PM
dryad001's Avatar
I had a 243 code and it was engine overboost condition, my MBC line was kinked.
Old Apr 23, 2005 | 02:27 PM
Jamie@WORKS's Avatar
Is your Boost Control Solenoid plugged in?
Old Apr 23, 2005 | 06:53 PM
dryad001's Avatar
That has nothing to do with that. On the stock ecu with an MBC will create a 243 code which will be almost like the fuel cut-off, I just replicated it today. But the only bad thing it will keep the engine light on which will be a rich "tune" without some sort of piggyback or standalone.
EDIT: Yes the solenoid must be plugged in, read it wrong
Old Apr 24, 2005 | 06:19 AM
yellowman's Avatar
I do not have the solenoid plugged in. I will try that first. I didn't find any kinks in the lines. Will not having the solenoid hose tips not capped off make a difference?
Old Apr 24, 2005 | 06:39 AM
mikesevo8's Avatar
Having the electrical plug connected is all you need. If it was unplugged, that is why you got that code.
Old Apr 24, 2005 | 07:58 AM
dryad001's Avatar
It is a MBC, it may be a little spikey, I know the one I have is and coming home last night I threw the code again. I need to get my EBC back from HKS. This MBC thing is starting to **** me off
Old Mar 1, 2013 | 09:17 AM
Howulikemyevo's Avatar
So, i got that code today by just start the car on. Po 243. Try to find out later n let u know.
gallas
Dec 9, 2010 11:53 AM
finallyaevowner
22
Jul 22, 2010 07:30 PM
apevo8
10
Nov 17, 2007 01:44 PM
