Help with PO139 Code
Old Apr 17, 2007 | 02:06 PM
apevo8's Avatar
hey guys, i just threw the PO139 code, reading Heated Oxygen Sensor Circuit Slow Response (1 of 2), i already have an o2 simulator wired up since i have a test pipe, correctly and blinking, so does this mean the o2 sensor in the front is messed up or what...how can i fix this??.....thanks
Old Apr 17, 2007 | 02:10 PM
apevo8's Avatar
i've already searched for this and didnt find anything about it, also 2 really old posts from 2005, please help me out, thanks
Old Apr 17, 2007 | 05:32 PM
GBEvo's Avatar
I have the same problem. I have the PO138 and PO139 and have cat delete pipe and perrin O2 simulator. O2 simulator is still blinking as well. I searched around and am pretty sure these codes are for the rear o2 sensor so if you find out, I'd like to know too. Good Luck.
Old Apr 21, 2007 | 09:27 PM
apevo8's Avatar
bump......nobody knows??
Old Apr 21, 2007 | 09:39 PM
nightwalker's Avatar
does it specify bank1 sensor1 (b1s1) or (b1s2)?
Old Apr 21, 2007 | 11:01 PM
kayyoevo8's Avatar
i also had the same problem. bought a rear o2 sensor and it was fixed.( i have the mechanical fix for my test pipe). i also have an o2 simulator.
Old May 9, 2007 | 06:14 PM
apevo8's Avatar
it said b1s2, so maybe change the rear o2 sensor
Old Sep 4, 2007 | 04:50 PM
apevo8's Avatar
bump....no1 has an answer??? or suggestions?
Old Sep 4, 2007 | 04:58 PM
smokedmustang's Avatar
Bank 1 O2 sensor is the one by the turbo, if that is bad, you need to replace it.
Old Nov 17, 2007 | 10:50 AM
Argentinopower's Avatar
same problem
I got a EVO8, I just replace 02 sensor after cat for a brand new but im still have same check engine light on. I don't really care about the light, but I do about gas millage. Do any1 know if 15 mpg is ok?.. I just bought the car, and I don't know much about it.
02 sensor is new and I put back the cat. I did the welding and after that I install the 02 new sensor.
Why i keep getting check engine light on?
what is a test pipe??
if my AIR fuel mixture gage is not install correctly do that matters?
I just got 1 install but it doesn't read right.. I can tell. Just go back and forward 4 no reason.
please help
thank u all
Old Nov 17, 2007 | 01:44 PM
20Grockit's Avatar
you running a wideband??
gallas
Dec 9, 2010 11:53 AM
finallyaevowner
22
Jul 22, 2010 07:30 PM
dbdude
15
Nov 8, 2005 03:34 PM
Az3ar
Jun 18, 2004 07:37 PM
