Evo 6 rear dif/ suspension
Old Jul 20, 2010 | 02:30 PM
  #31
KX250Fmotoracer's Avatar
Originally Posted by alexisrc
you can get the evo 6 ayc out of an evo x
If its the same AYC, thats good to know for the futre if I ever need parts. The Evo I'm bringing in has the full AYC from the diff, ecu, G force sensors, etc. This should be good
Old Jul 22, 2011 | 11:37 PM
  #32
discopotato03's Avatar
I really really wish someone could show me pics of the rear body crossmember that the non AYC mechanical diffs front alloy cross piece bolts to . Its the one that has the two vertical outer studs but importantly the different steel skin incorporation the inner pair of bolts captive body nuts .
I think in a non AYC Evo its part of the bit welded on with the fuel tank mounting tabs .
In Australia we have 95% of Evos AYC which is the opposite to the US where most Evos have conventional rear diffs . My 6 is a GSR meaning damn AYC and I want a conventional rear end but need to fit those extra captive nuts to properly mount the conventional diffs front alluminium cross brace .
PLEASE PLEASE be a world first and post pics of the body mounts for that RS type front (of rear diffs) mount brace . I've searched high and low for weeks and found nothing which amases me .
Sorry so intense , cheers A in Oz .
Old May 18, 2012 | 05:53 PM
  #33
Speedy-gunz's Avatar
all ayc r almost the same even the x the bracket make the difference i have done it
Old May 20, 2012 | 08:07 AM
  #34
Blitz_b9's Avatar
hey people is it true that Evo VI GSR Diff breaks at high (5000+ rpm) launches?? & RS diff is more stable at high rpm launches?? i was informed not to do launches above (4500rpm) in my EVO VI..? is it true?
Old May 20, 2012 | 09:31 PM
  #35
Yogi_B's Avatar
It might do, or it might not, it's a gamble.
It's also like your gearbox surviving a launch, it might break, or it might not.
Although overall an RS diff is stronger.
Old May 20, 2012 | 09:33 PM
  #36
Blitz_b9's Avatar
is there any particular way that u can identify a RS diff?
Old May 20, 2012 | 10:49 PM
  #37
Yogi_B's Avatar
Yep, they are very different to an AYC diff.
The RS diffs look just like a regular rear diff, they are steel cased painted black, heres one here:
http://www.lancerregister.com/showthread.php?t=354128
While the AYC diff is a big lumped aluminium case of fail with hydraulic lines going into it, if you do a google image search you'll find them, or here:
http://www.lancerregister.com/showthread.php?t=397445
Old May 21, 2012 | 10:15 AM
  #38
Blitz_b9's Avatar
;D & the best part is RS Diff is double the price of a GSR Diff,,
Old May 21, 2012 | 10:50 AM
  #39
Blitz_b9's Avatar
is it weird to run two different suspension sets.. cusco for the back & HKS in the front?
Old May 21, 2012 | 10:57 AM
  #40
BCspeed34's Avatar
You can use Evo 7-9 mechanical differentials with the Evo 6 subframe and control arms. Just make sure to use the diff mounting bar and axles.
Also I would try to use matching suspension components, makes dampening adjustments much easier.
Old May 21, 2012 | 08:42 PM
  #41
Blitz_b9's Avatar
thanks mate..
Old Sep 22, 2014 | 01:27 AM
  #42
checksum's Avatar
Just question, does anybody know if I can fit the diff from an EVO4 RS to a E6 with all the rear bits from the RS E4
DJKneo
Sep 30, 2010 05:45 PM
Evo8564
Nov 9, 2005 01:28 PM
EVO8emUp
Jun 17, 2005 11:54 AM
WHTCT9A
95
May 10, 2005 01:52 PM
Whooopasss
31
Jan 7, 2004 11:17 AM
