map rev3 intake manifold failure
Old Jan 4, 2010 | 01:00 AM
tripperfx3's Avatar
Love seeing vendors like this. Sorry you had the trouble with it, but at least they're fixing it with a quick turn around.
Old Jan 4, 2010 | 01:19 AM
Strict7gsr's Avatar
I hope you get running soon man...and... to map for being responsive....
Old Jan 4, 2010 | 03:05 AM
tscompusa2's Avatar
and to think i had it all done .....
o well alittle extra work never hurts. I went ahead and replaced the rear roll stopper motor as well since it was easy access with Intake mani off. that thing sucked to get off and change.
Im changing all my motor mounts back to stock, 2.3 + no balance shafts = sucks with hard mounts.
Old Jan 4, 2010 | 03:09 AM
tscompusa2's Avatar
Originally Posted by demodeakin
Thanks for the Heads up.... I am going to test mine before I do an Install in a week...... its a beautiful Mani... the Porting is Perfect
yes its a beautiful manifold inside and out. i was shocked when it had a leak. pretty easy to get off tho, took about 45min.
Old Jan 4, 2010 | 06:38 AM
RockmanX's Avatar
and i thought all your parts were PERFECT!!!!. LOL i guess your not ready for action just yet glad you found it now while you were still testing the parts and making sure its all working properly. just lets others know to check more closely is all. im sure that monster will be up this week he did say one day turn around
Old Jan 4, 2010 | 06:42 AM
tscompusa2's Avatar
ya. thank god for boost leak testing. its something every turbo car should come with by default. it can also save you from a catastrophe as well if you have a fuel leak or something bad.
gave me an excuse to remove all the aftermarket motor mounts also. im not dealing with a ****ing earthquake equipt evo.
Old Jan 4, 2010 | 10:10 AM
VRSF Tiago's Avatar
Hopefully MAP compensates you for the time involved in removing the IM. Every shop makes mistakes and map's doing the right thing by replacing the defective product but that doesnt make up for the time he's lost with the install/uninstall of the product. Overnight shipping both ways should be expected, not a privelage.
Old Jan 4, 2010 | 10:26 AM
Gordian79's Avatar
That's a little crazy there to ask for labor money.Most performance parts don't carry a warranty said or implied.
Welding cast aluminum or cast anything you tend to create gas pockets sometimes.It happens map is doing the right thing.
Old Jan 4, 2010 | 12:12 PM
ChrisCarey's Avatar
Sounds like Bob is getting you taken care of sir, I will also respond via PM. I sincerely apologize for this inconvenience and as Bob mentioned all of our manifolds are supposed to be pressure tested before they leave our facility, I will be having a word with my fabrication team...
Old Jan 4, 2010 | 12:52 PM
tscompusa2's Avatar
np i responded to your pm. Its off and ready to ship.
Old Jan 4, 2010 | 07:34 PM
tscompusa2's Avatar
so ill update this thread to let everyone know that map is sending fedex here overnight to come and get the manifold and fix and send back with new gasket. Not surprising though, because I've always had great experiences with this vendor. My clutch, injectors, exhaust manifold port, and a slew of other parts were all purchased from MAP.
josh234man
Jan 21, 2017 04:01 PM
eXtreme-Speed
Aug 7, 2016 06:14 AM
UHOH5OH
40
Sep 27, 2013 02:45 PM
AJsGenerX
Mar 29, 2012 05:19 PM
MizzCovert
12
Jul 6, 2009 03:41 PM
