Evo VIII gas smell under boost/wot ?
Old Jan 20, 2010 | 02:36 PM
88evo05's Avatar
Like the title says I recently puchased a 05 evo with 40,000 miles and under boost/wot I allmost instantly smell gas fumes while driving. When I let off and return to cruising speed the smell disipates. I'm looking for a little help with this has anyone had a similar problem, ideas on what to check?
Old Jan 20, 2010 | 02:47 PM
kwanza's Avatar
You should not smell gas in the cabin. Check the fuel pump, it is under back seat.
Old Jan 20, 2010 | 02:52 PM
EmeryatSTM's Avatar
Also, Check the injector seals.
-Em
Old Jan 20, 2010 | 03:49 PM
oneofakindtrini's Avatar
+1 On The Injector Seals.
Old Jan 20, 2010 | 03:55 PM
Lancerguy'03's Avatar
+2. i think i need to check mine again.....an easy way to check them is a boost leak test.
Old Jan 20, 2010 | 04:10 PM
88evo05's Avatar
Forgot to say car is all stock.
Old Jan 20, 2010 | 04:14 PM
boostedwrx's Avatar
Do what everyone else said - the injector seals can go bad just being out in the weather, regardless if the car is stock or not.
Old Jan 20, 2010 | 04:22 PM
88evo05's Avatar
I'll start there thanks guys.
Old Jan 20, 2010 | 04:28 PM
to add what i said before...i had a bad injector seal few weeks ago and it smelled like raw gas in the car....so thats probably what it is.
Old Jan 26, 2010 | 01:50 PM
mak1000's Avatar
Injector seal leak is dangerous. You should check that ASAP.
Old Jan 26, 2010 | 01:56 PM
Pal215's Avatar
This is highly unlikely but, was the car previously involved in an accident? There are ventilation points that could have been left unrepaired after previous body damage. When i was rear ended next the the passenger side quarter panel, the entire body section flexed. After that every time I hit boost I would smell engine fumes in the cabin. After the repair was done the smell disappeared. Check this last if you have not found a solution yet.
Old Jun 17, 2011 | 10:34 AM
rsonistxl's Avatar
i just bought my Evo about 2 weeks ago and for some reason it smells like gas now, idk where to start
Old Jun 17, 2011 | 10:42 AM
Ian0611's Avatar
Also note that just because you bought it in stock form that doesn't mean it's always been that way. A lot of guys put their car back to stock before they sell it.
Old Jun 17, 2011 | 12:50 PM
8UpUrV8's Avatar
I had a similar issue. Turned out to be a ruptured fuel hose on the drivers side of the fuel rail.
Old Jun 17, 2011 | 01:06 PM
evol911's Avatar
I would check if the car was put back to stock that the OEM boost lines with pills were reinstalled. I'm new to DSM's/Evos but its my understanding that the stock MAP sensor doesnt read to full boost so if your boost pills/ lines were incorrect maybe you aren't boosting fully and the computer is just dumping the "pre-determined" amount of fuel in for where it thinks the boost should be causing you to run richer and smelly!
Or its a small fuel leak somewhere.
Evolpixy
May 11, 2017 11:26 AM
210ralli
Jan 15, 2012 06:16 PM
ltwayner
Jan 25, 2005 09:06 PM
surfocean
Dec 26, 2004 11:32 AM
Evilution VIII
Sep 10, 2003 11:44 PM
