SES CEL On - Possible to Check for Code(s) Without Scanner?
Old Feb 23, 2010 | 08:26 AM
november's Avatar
SES CEL On - No Spark or Turnover Until 7th Time Trying to Start The Car.
I have an evo ix se with light mods and tephra v6.
This morning when i went to start up the car I could hear the fuel pump but got no spark/turnover at all.
After trying to start it a good 6/7 times it started up - followed by the SES light staying lit.
Is this a common issue? I'm not sure what would cause no spark - perhaps my rotor is going bad?
I used to have an integra before my evo ix and with the integra I could short a plug and get the CEL to flash respectively for the code being thrown.
Is this not possible with Evos and if not is there a recommendation for a scanner? Could I use something like evoscan scantool for this as well?
Old Feb 23, 2010 | 10:04 AM
metalsaber's Avatar
You can use EvoScan to pull the codes, but you need a Tatrix Cable. If you have that, you can pull the codes and clear them if necessary.
If the pump is running, then it's getting power. But if you aren't getting any crank/turn over, then it sounds like a starter. Just to test the batter, put the key to the on position and check to see if you get headlights, radio, A/C, etc. That can eliminate a battery issue.
Old Feb 23, 2010 | 10:28 AM
november's Avatar
I was able to start the car today.
There have been 3 other instances where I would try to start the car, it wouldn't crack and then it would work after a 2/3 tries......but this morning is the first time it took 7 tries and the SES/CEL came on.
Old Feb 23, 2010 | 10:45 AM
chaotichoax's Avatar
I downloaded scantech and checked mine with my tactrix cable and laptop before
Old Feb 23, 2010 | 10:48 AM
CCBOYNO's Avatar
Could be crank angle sensor
If a USDM ECU are the same as a JDM You can flash the codes by shorting pin 1 to pin 4 on the ODBII connector
Old Feb 23, 2010 | 12:08 PM
november's Avatar
Interesting - I'll have to look into this - I'll probably stop by autozone on the way home but most of those employees don't know what they're doing.
Old Feb 23, 2010 | 12:16 PM
metalsaber's Avatar
The plug is directly under the dash right about where your right knee would be. Shouldn't be too hard.
Old Feb 23, 2010 | 01:41 PM
SmurfZilla's Avatar
Scantech X2....saved my bacon more then once. more informative the Autozone
Old Feb 25, 2010 | 07:03 AM
november's Avatar
So this is strange - I went to the bodyshop yesterday to check out a dent and get an estimate. Upon leaving the lot I had to haul *** because of traffic - Did some tokyo drifting and the CEL went away.
So I'm not really sure what happened and I wanted to know the issue but at the same time it's gone now - I do assume, however, it will appear once again.
Old Feb 25, 2010 | 07:42 AM
metalsaber's Avatar
I've had codes cycle by themselves. You should still get the cable so that you can always tell whats going on with the car.
itsmeek
Sep 2, 2015 09:22 AM
LeslieB
Feb 23, 2015 08:24 PM
mr2turbo18
Apr 21, 2014 05:35 PM
naudlee
17
Aug 15, 2012 01:04 PM
Jp7
Jul 29, 2010 07:38 PM
