Evo won't start, no click from starter
Old Mar 6, 2010 | 08:31 AM
rayray7734's Avatar
so how hard is it to replace the starter?
Old Mar 6, 2010 | 10:57 AM
xuder's Avatar
Ya got this problem resolved it was my starter, replaced it with a new one and now my ignition switch is going out, it takes a couple of tries sometimes to get the car started. But better than before when it didn't start at all.
Thanks everyone for the help!
Old Mar 6, 2010 | 01:53 PM
Kakarot's Avatar
I had a problem with mine starting today and it turned out that the plug slid of it's connection. I was about to go out and buy a starter until I saw this thread and people talking about it coming unplugged.
Old Sep 15, 2011 | 10:43 PM
prowakeskater's Avatar
Thanks to this thread, I didn't get stranded in the middle of a 13 hour overnight drive home. Love this ****ing forum. Evom4life
Old Oct 4, 2011 | 05:21 PM
RenosEVO's Avatar
anyone know where the starter is located?i cant seem to find it i got a 05 evo 8
Old Oct 4, 2011 | 07:20 PM
barneyb's Avatar
If you are looking from the top you will never find it. It is on the front (radiator) side of the engine, covered by a heat shield. Remove the under cover, cross bar and exhaust and you are all set to remove the starter.
Old Oct 5, 2011 | 04:30 AM
cs82685's Avatar
Jesus you have to move that much **** just to get to the starter, what a pain in the ***
Old Oct 5, 2011 | 04:39 AM
bigben's Avatar
Vibration is all you need for something to work it's way loose.
Old Oct 5, 2011 | 05:52 AM
MJ23FE's Avatar
You DO NOT need to remove anything but the undertray to get to the starter.
I was able to take out my bum starter and swap in a replacement in about 30 minutes on the street. Jack the car up, unbolt the starter, unplug, put new starter in place, plug in, bolt it up, and done.
The exhaust and cross bar are no where close to effecting the install and do not need to be touched!
-Jalal
Old Jan 24, 2023 | 02:10 PM
WelDun1's Avatar
Starter problems
This is the starter solenoid connector/wire Does anyone else's look like this? I don't see any wire cover under the heat sheath. The wire itself looks a little frayed and spread out maybe even broken? I've tried to find another for comparison but can never get a glimpse under the heat sheath.
Old Jan 24, 2023 | 02:42 PM
ViciousLSD's Avatar
looks fine to me
mrhussain
Dec 28, 2016 05:36 AM
EvoGSR8
20
Mar 22, 2014 08:44 AM
ant_turbo
18
Jul 4, 2012 09:01 AM
EvilTechnology
Jun 6, 2012 06:52 AM
skibo84
Aug 18, 2008 11:26 AM
