HELP! Laggy Throttle + Car Sputter Like Crazy
Old Mar 18, 2010 | 10:15 AM
bboy_RES's Avatar
a couple days ago my car started acting up. sometimes my throttle would be laggy. i would try to accelerate and my car would take a couple seconds before it would respond. kinda feels like crazy turbo lag or something. then after a couple minutes of driving it would start to sputter like crazy when i would try to accelerate from a stop, but then after the sputtering it would finally begin to accelerate. i can also feel the car sputtering while i'm just cruising. at first i thought it was a boost leak so i got a new coupler for my LICP, but that didnt fix the problem. i regapped my spark plugs, but that didnt fix the problem either. then i thought my fuel pump was going bad so i installed a new one last night, still no luck. now i'm thinking my spark plugs are actually fouled. any other ideas guys? i installed an Invidia o2 housing and an AMS FMIC last week. not sure if any of those mods could be related to my issue.
Old Mar 18, 2010 | 10:31 AM
chaotichoax's Avatar
boost leak test?
how did the plugs look when you pulled them out to regap?
Old Mar 18, 2010 | 10:36 AM
heel2toe's Avatar
It sounds like your car is sputtering because it is running too rich. Just because you replaced your coupler on the LICP doesnt mean your car is free of boost leaks. From my experience the only sure way to tell if your car is leaking is to perform a boost leak test. You would be surprised the amount of air ive seen rush out of my couplers even thought I thought they were on tight. You said you checked your plugs and regapped them? The plugs may be gone so it may not be a bad idea to replace them. What did you gap them to? Other than that the only thing I can think of is that your car just needs a retune since youve installed a couple different parts. Good luck and keep us posted.
Old Mar 18, 2010 | 10:59 AM
bboy_RES's Avatar
Yeah I made a boost leak tester but the valve stem I used was defective. It doesn't let air in. Lol. I'm picking up spark plugs right now. I'll let you guys know what happens.
Old Mar 18, 2010 | 11:02 AM
bboy_RES's Avatar
I gapped my plugs to .21-.22.
Old Mar 18, 2010 | 02:11 PM
kronik5383's Avatar
did you check your air flow sensor? sounds like the symptoms of a bad/dirty one
Old Mar 19, 2010 | 10:47 AM
Poik242's Avatar
Sounds like a misfire. If your plugs are fouled sometimes the only way to cure that is to just get new ones.
Old Mar 19, 2010 | 09:09 PM
bboy_RES's Avatar
yeah i'm planning on getting new ones tomorrow. hopefully that solves my problem. i havent driven my car in 2 days! i'm dying! haha.
Old Apr 10, 2010 | 01:51 PM
EvoVIII :D's Avatar
How many miles on the car? It could be one of your coils going bad
Old Apr 10, 2010 | 02:10 PM
Evoryder's Avatar
Boost leak test based on assumption? Gotta get to it and stop wasting money on parts you may not need.
Boost test --> check for turbo shaft play -->check plugs --> compression test -->check tune
Old Apr 10, 2010 | 06:01 PM
bboy_RES's Avatar
turned out to be my front o2 sensor. i used shrink tube when i extended the wires, but some of it melted so the wires got crossed. i fixed it now though.
LancerBenny
Lancer Troubleshooting
Jun 30, 2016 08:11 PM
vxevolutionxv
11
Jul 6, 2009 09:37 PM
jlam
Mar 4, 2008 10:27 PM
EVOONYOASS
33
Apr 19, 2006 05:02 PM
Biggwill91183
Mar 29, 2005 09:02 PM
