Who's hit 60,000 miles and havent done the service yet?
#31
the timing belts should be changed at 60-70k. There are thousands of broken timing belt stories over the last 2 decades with the 4G63 by people trying to get 100k from them. Once the belt breaks you will bend valves at the minimum and you will realize that being lazy and cheap wasn't smart.
#32
1 Post
#38
u do not need to replace water pump at 60K, but you u need to replace ur sparkplugs per manual.
i just done mine at 62K, things u need to change per manual.
timing belt :at the time of replacement my old timing belt looks as good as new
drive belt :at the time of change drive belt looks worn out LOL no teeth is missing
serpentine belt : I skipped it at 30K at the time of replacement its cracked but no teeth missing
trans fluid
transfer case fluid
differential fluid
cabin filter : its moldy and dusty..i used fabreze to clean it every 10K,
sparkplugs : the old sparks look worn out but healthy still..they show strong and healthy engine on all cyls
coolant
engine oil and filter.
hope its clear things up for the confusions, if u got burning hole in ur pocket go ahead replace ur water pump otherwise not needed
trans fluid
transfer case fluid
differential fluid
coolant
#39
My 68K maintenance
Plugs
Idler pulley
Tensioner pulley
Timing belt
Balance belt
Tranny fuild
Clutch
Also added a set of Tein mono-flex coilovers
and a four wheel alignment
I forgot all about the cabin filter, have to check it.
Plugs
Idler pulley
Tensioner pulley
Timing belt
Balance belt
Tranny fuild
Clutch
Jim in Tucson
66
Sep 1, 2011 07:03 AM
