just bought a turboxs TBE.
Old Mar 27, 2010 | 10:56 AM
Charlie-Y's Avatar
Hello,
Just got my turboxs TBE i ordered from their website for my Evo 8 .
Removed all stock pipes and found out that the stock cat converter flange and
diameter did not fit the turboxs pipe, my biggest concern was that the turboxs
downpipe and donut ring was too big to fit the stock turbo pipe.
Am I missing anything ? , or do I have to end up swapping a whole new turbo?
Old Mar 27, 2010 | 11:05 AM
8UpUrV8's Avatar
I run the TXS TBE, use the TXS donut gasket, it works. The stock cat is smaller than the exhaust- but the flange will bolt up. You need a high flow cat or test pipe to take full advantage of the TBE
Old Mar 27, 2010 | 12:37 PM
phishy's Avatar
Yes I believe if you are running 3" from DP down you will need high flow cat or test pipe so that the piping doesn't tapper down @ the cat. If you're for a test pipe Topspeed Autosports has some Invidia 3" TP for a good price shipped. I think there's also a few vendors here with high flow cats if you go that route.
Old Mar 27, 2010 | 01:22 PM
Charlie-Y's Avatar
Do I need to remove the stock donut gasket from the turbo pipe?,
even with the stock donut removed the diameter of the turbo pipe still be too
small for the txs donut gasket.
Old Mar 27, 2010 | 03:35 PM
8UpUrV8's Avatar
Remove old donut with flathead screwdriver, install new donut- yes it has a bigger outside diameter but the inside is the same. It will fit great when put together.
Old Mar 27, 2010 | 04:02 PM
Charlie-Y's Avatar
I'll try that thanks.
Old Mar 30, 2010 | 05:38 PM
Charlie-Y's Avatar
Okay , I'm having trouble removing the old donut gasket , it seems to be weld it with the turbo
pipe.
anyone , have a method on removing without damaging the turbo pipe?.
Old Mar 30, 2010 | 06:11 PM
JFuego777's Avatar
Shouldn't be welded....they can be a tight fit though...just pry it off with a pry bar or screwdriver...You need to pry between the "donut" and the flange on the turbo.
Old Mar 30, 2010 | 06:41 PM
Charlie-Y's Avatar
I tried that , the gasket wouldn't budge.
Old Mar 30, 2010 | 07:22 PM
EJW2202's Avatar
You might end up having to hack at it. Mine wouldn't budge either so i cut into it with the screwdriver I had and basically tore it apart so I could get it off the o2 housing.
Old Mar 31, 2010 | 05:47 PM
Charlie-Y's Avatar
Thanx guys , I finally rip that old gasket off , now all I'm waiting for is the txs
cat delete pipe.
Do I need take it to a local shop to install it for me once I got the test pipe , just incase their is a fitment issues?.
or will the txs tbe fit without any problem?.
Old Mar 31, 2010 | 08:35 PM
2slow4u's Avatar
I say just go to a local shop and have them make you a 3'' test pipe, until then run open dp.
Old Apr 2, 2010 | 11:34 AM
Charlie-Y's Avatar
Update !
Just recieved my test pipe and finish installing my TBE.
All I got to say is this thing sounds bad ***.
From the size of it I thought it was going to be obnoxious loud but it wasn't.
Not to loud nor quite.
Old Apr 2, 2010 | 11:56 AM
phishy's Avatar
Clip if you can
Old Apr 4, 2010 | 09:55 AM
8UpUrV8's Avatar
Didn't I tell you everything would go on great?
C5z
Cobb AccessPORT
Sep 11, 2014 12:35 AM
user02391x
Aug 1, 2012 03:23 AM
kevinjohnson
Dec 30, 2010 12:22 PM
Mishi9
Oct 7, 2010 05:41 AM
IspyEvo
Jun 25, 2010 02:17 AM
