My FP Black numbers
Old Apr 27, 2010 | 03:13 PM
  #76
wizzo 8's Avatar
Originally Posted by AutOtaku
The 4g63 Engine is a beast. Stock block with that much power holding it down. How long will it last you think? I am still doing research on the motor before i do my upgrades so it's crazy to see these numbers etc.
I dont do any road racing and only get on it maybe twice a month unless Im at the dragstrip. The dragstrip is where it will see the most abuse. Its my DD so I think it should last a while. Im saving for internals now so I will feel feel better once I get them in. If I took it road racing I dont think it would last too long but you never know.
Old Apr 28, 2010 | 06:41 AM
  #77
ablan029's Avatar
Originally Posted by EvoJoeIX
if hes only at 75% duty cycle on 880's theres absolutely no reason to get 1000's
doesn't straight 93 pump require more flow??
Old Apr 28, 2010 | 06:58 AM
  #78
wizzo 8's Avatar
The Meth makes up for the smaller injecter size
Old Apr 28, 2010 | 09:43 AM
  #79
RockmanX's Avatar
nice number dude 93 oct and meth i see. Im not a meth fan at all and will not consider it myself. lol but nice to see what your laying down i wonder what im going to do?
Old Apr 28, 2010 | 10:03 AM
  #80
wizzo 8's Avatar
Thanks. I wasn't either untilled I found out about all the failsafes out there. I got them all covered so its safe.
Old Apr 28, 2010 | 11:24 AM
  #81
RockmanX's Avatar
good deal hommie
Old Apr 28, 2010 | 11:54 AM
  #82
EvoJoeIX's Avatar
exactly
when meth is set-up right it is VERY safe
when e-85 isnt available, meth and 93 is the only other way to make good power cheap
Old Apr 28, 2010 | 02:04 PM
  #83
SmurfZilla's Avatar
Agreed.
If you have no E85 available you should be pissed.
Old Apr 28, 2010 | 02:09 PM
  #84
meat_EVO's Avatar
a black for the X would make some serious power.
Old Apr 28, 2010 | 02:11 PM
  #85
RockmanX's Avatar
ill pass on meth 93 combo to each his own glad its working for you.
Old Apr 28, 2010 | 06:26 PM
  #86
t-revzr's Avatar
Originally Posted by High_PSI
1500RPM Hit? I Doubt that.
And yes he's right on my car I took a 1500 hit on spool up. My buddys red tho which is a evo 9 spools 1000 rpms faster than mine..
Old Apr 28, 2010 | 08:19 PM
  #87
High_PSI's Avatar
There has to be something wrong.
Old May 1, 2010 | 08:51 AM
  #88
wannaevo's Avatar
Very Nice setup on your car and some awesome power to.
Old May 1, 2010 | 01:33 PM
  #89
DuderMagee's Avatar
wow those are higher numbers than what I thought the Black would give
good stuff
Old May 1, 2010 | 06:45 PM
  #90
wizzo 8's Avatar
Well I went to the track today to see what it would do. I only got 3 runs in and all of them were identical. I'm not used to the new twin disk exedy so my 60ft sucked. 2.0 on every run. I was cutting 1.5 on the stock clutch. I just need to learn to slip it more. Anyways every run was 12.0@125 with 2.0 60ft. There was also a nice head wind. I'm going back Friday to try and improve my launch
