HELP! Car won't start!
Old May 11, 2010 | 12:40 PM
RSGuy's Avatar
Hey guys,
I went to leave work last night and I couldn't get the car to start. It first ran for about f seconds and then died. From then on I couldn't get it to start. I'm thiking it might be either a bad alternator, fuel pump, or possibly crank position sensor. I have AEM EMS and a walbro fuel pump. Normally with the EMS when you turn the igntion to ON, it makes this 'start-up' electrical type sound. Now, it still makes that sound but erradically and doesn't stop doing it. Very strange. Does this sound like a fuel pump ssue or alternator maybe? I hope I made everything clear. Let me know if I can be more specific. I would appreciate any help. Thanks guys.
fred
Old May 11, 2010 | 12:50 PM
jaredh's Avatar
sounds fuel related IMO. you need to do some diagnostics. maybe get a friend or family member to help you. if you don't think you can figure it out look for a good mechanic. any experienced mechanic should know the procedure for diagnosing your problem. good luck!
Old May 11, 2010 | 01:19 PM
nonschlont's Avatar
I had a similar issue, and (for me) it was a wire on the fuel pump, and also had a bad coil pack...
GL
Old May 11, 2010 | 06:39 PM
dreyfus14's Avatar
When this happened to me one time, the ecm plug wasn't fully locked in on my EMS and worked its way out out over time. check the connection on your ems to be sure all plugs are fully pushed in before digging deep in diagnostics.
Tyrel Bursaw
Jul 23, 2018 02:26 AM
Billy@EnglishRacing
Jul 6, 2008 03:05 PM
4cefed
May 12, 2008 12:14 AM
David Buschur
Jun 23, 2006 10:02 AM
